Old 10th November 2004, 04:00 PM   #1
Send a message via AIM to bhg41088 Send a message via MSN to bhg41088 Send a message via Yahoo to bhg41088
Default Peecreek Crossover
Im buying th parts for the crossver and it's getting expensive. I need to know what brand/type of Resistors, Capacitors, and Inductors to get to keep costs low.
Wheres a good place to buy this stuff?
Inductors:
1.5mh, 14 Awg
1.2mh, 18 Awg
.30mh, 18 Awg
Capacitors:
29uf Electrolytic
22uf Electrolytic
6.8uf Poly.
8.4uf Poly
Resistors:
8 Ohm
3.5 Ohm
I Know what type of Caps i want,, But what kind of Inductors should i use, same with the resistors. If anyone has a parts list for this project, i'd be thankful. TIA guys.
Old 29th December 2004, 06:03 PM   #2
reviving this.
Old 30th December 2004, 04:10 AM   #3
wigginjs's Avatar
Well, I know that Wayne J does the vast majority of his shopping at Parts Express, so I would guess thats where he got his stuff. Also, he seems to be a big fan of Dayton, so I would imagine the caps and resistors are probably Dayton brand. As for inductors, get the largest wire size that you can (reasonably) afford, film if possible.
http://www.partsexpress.com
The Four Chairs
DIY Home Theater
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 04:21 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Help with crossover for Sub Amit_112dB Subwoofers 4 4th August 2007 04:01 AM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Page generated in 0.08340 seconds (68.41% PHP - 31.59% MySQL) with 10 queries
