Old 10th November 2004, 01:06 AM   #1
D_GR8_1 is offline D_GR8_1  Australia
D_GR8_1's Avatar
Default D'Appolito with Visaton Drivers. No BASS!!
I made two speakers in a D'appolito config using the Visaton W130S & DW72 drivers.
The Woofers W130S are 4Ohm each & the DW72 is 8 Ohm.
My plan was two 4 Ohm in series to give me 8Ohm which in turn is paralleled with 8Ohm Woofer.
Woofers are bandpassed at 90Hz & 5Khz.
Tweeter is HP at 5Khz.
When I play them, I have Pioneer Amp, tried it with Gainclone, and various other amps, unless I use an equaliser or tone control, the speakers produce very little bass.
Does anyone know what the problem is?
Old 10th November 2004, 02:13 AM   #2
jdybnis is offline jdybnis  United States
Most of the "bass" I hear in music happens between 40hz and 80hz.
If you roll off your woofers at 90hz you are cutting out all the bass.
Visaton BG20 hissing and lacks Bass filholder Full Range 6 26th January 2007 01:17 PM
Visaton MHT12 & TI 100 drivers Pulsar Swap Meet 8 24th January 2007 01:06 PM
TL and the derivatives using two midbass drivers in a D'Appolito style configuration Puggie Multi-Way 7 7th January 2005 02:04 PM
Visaton mid-bass wxn Multi-Way 3 29th December 2004 12:21 PM
Visaton drivers .... any experience? alvaius Multi-Way 2 25th September 2002 07:16 PM
Page generated in 0.06905 seconds (70.81% PHP - 29.19% MySQL) with 10 queries
