Horn Loaded Line Array ?
Old 15th November 2004, 02:06 AM   #11
johninCR is offline johninCR  United States
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Chipco,
That was just round 1 before trying to make it smaller. I've gotten it down to under 18" from the front of the baffle on the right side in the drawing to the wall, so under 18" deep and the left front corner of the baffle is only 10". Still 33-150hz response. This small one may work out really well because the horn length is right at 90" which just happens to be the wavelength of 150hz, so it looks like the phase of the horn output and the front driver output will be right on at the acoustical crossover point.
It's looking like 3 sheets of plywood will be enough for a pair and I can probably get away with 1/2" due to the much shorter distances and extensive dividers/braces. I need to draw it out and just go ahead and build one.
I'll keep you posted.
Everyone has a photographic memory. It's just that most are out of film.
Old 15th November 2004, 04:45 AM   #12
rcavictim is offline rcavictim  Canada
rcavictim's Avatar
JohninCR,
That is a clever approach! I will follow this with interest, because IMO things that are clever are INTERESTING! Congratulations on the 'rush of sh*t to the brain'.
"There are more worlds than the one you can hold in your hand." Albert Hosteen, Navajo spiritual elder and code-breaker, X-Files TV Series.
Old 15th November 2004, 05:16 AM   #13
chipco3434 is offline chipco3434  United States
John, your idea looks good enough to steal.
Old 15th November 2004, 05:23 AM   #14
paulspencer is offline paulspencer  Australia
paulspencer's Avatar
PE have some Vifa drivers on a JBL buyout going cheap right now. They are 4.5" midbass drivers with 3.5mm xmax and an fs of 65 Hz. At $4 each, they are still cheap and let you get down deeper.
Old 15th November 2004, 07:54 AM   #15
Let's not jump the gun we're still talking about high Fs and Qts drivers in about a 30hz horn. It might not sound good. Construction is pretty simple, so I'll have to give it a try. I also tried some fairly wide variations of T/S parameters since I don't have NSB's just something similar, and the response changed very little. I think I won't even bother measuring mine.
I tried modeling 8 drivers for a test run, but it would need a whole redesign.
Previous post edit...the 10" from left corner is to the wall, so this thing really hugs the corner and the baffle is going to need to be on an angle. Also in drawing the folds to scale it looks like a 20-22" depth of the right side will be required, but we're still talking about less than 2'x2' needed in the corner.
Paul thanks for the info on those drivers, but they won't work as well. I couldn't get them to go lower than 30hz without a tremendously longer horn. The short horn gave way too narrow a bandwidth and less extension. Plus they'd need a real xover that I want to stay away from.
Horn Loaded Line Array ?Hide this!Advertise here!
Front loaded and back loaded horn DrWoofer.com Subwoofers 14 12th April 2016 08:32 PM
Back loaded horn & Transmission line enclosures IG81 Full Range 1 18th December 2008 02:40 PM
horn placement in line array kan3 Multi-Way 10 1st July 2005 07:00 PM
Line Array Corner Horn for any 4" driver johninCR Multi-Way 42 1st December 2004 05:13 PM
Need help with horn-loaded sub slicemaster101 Multi-Way 26 17th September 2002 01:09 PM
