All,
Has anyone built Linkwitz's Orion speakers with XLS12 woofers instead of XLS10 he prescribes? I am considering building the Orions, but have read that some people feel the XLS10s are a bit limited in the lowest frequencies. First of all, is that a common understanding, or a view of the minority? Fixing the "problem" could be done by adding subwoofers to tackle f < 40 Hz. SL proposes an XLS12-based design. So, why not build the Orion with XLS12s from the start instead? Has any one done this? Any lessons learned? Thanks, Rasmus |
#2 |
PS. Of course replacing the XLS10s with XLS12s does not generate the same frequency response as keeping the XLS10s as dipole woofers and adding a XLS12 as a sealed box subwoofer, but anyway. Looking at the datasheets, the XLS12 is 2dB more sensitive @ ~110Hz, and 6dB more sensitive @ 50Hz.
#3 |
IMHO A longer throw 12" driver (DPL12, AV12) would only be worthwhile in an MTM configuration (Steve Dodd's Bob is a good example). The 12" XLS shares the 10" suspension and only gains 2.5dB from the extra Sd which isn't worthwhile. A change to 12" with a same-width midrange baffle will change the polar response - narrower than the Orion's would be better. The DPL12 has more distortion than the XLS above 60Hz. Such changes would require cross-over changes. A higher Q sub-woofer driver would also preclude using a 60W amp to force amp clipping before reaching the excursion limits above 22Hz.
Excursion limited dipole output decreases at 18dB/octave below Fequal (.17c/D) which is about 150Hz in the Orion woofer section. At xmax, the Orion woofers are good for 118dB @ 80Hz, 100dB @ 40Hz, and 82dB @ 20Hz. You get 3.5dB more if you use xsus instead. Midrange xmax limits you to 109dB @ 80Hz. This is either adequite (I built the orions and find them fine for 90dBC rock/techno and orchestral at realistic levels, etc.) or woefully insufficient (full-range reference level home theater needs 115dB for LFE and 105dB for the screen channels. Organ music may also have higher requirements). A longer throw 12" gets you 5-6dB total. Up top this lets the woofers keep up with the 6dB output increase from a pair of midranges. A sub-woofer gets you 6dB more output at the cross-over point (106dB with a 40Hz XO, enough to match the midrange). One XLS10 in a sealed enclosure gives you 11dB more at 20Hz in half space. Moving it to a corner gives you even more output - 12dB in theory, maybe 6dB in practice. A box woofer in a typical room gains another 5dB at 20Hz. Obviously you could use other/more drivers for even more output or less distortion. One dipole alternative that just keeps up with the Orion midrange in the last octave would be a pair of Tumults in a 24" H-frame, costing $2K for the drivers. You could also use a Parthenon for more money. Sealed sub-woofers are less expensive, smaller, and lower distortion from the reduced excursion. |
#4 | |
Down low you're excursion limited so it doesn't matter there either. The low sensitivity can even be regarded as a feature because it allows one to put together a fail-safe system (as in SL's 60W ATI amp) where you get reasonable output AND the amps clip before the woofers bottom. |
#5 |
Cult of the Infinitely Baffled (Resource for IB sub builders) |
#6 |
Thanks Drew for your extensive explanation. From what you say, I should be ok with the standard Orion config.
Rasmus |
#7 | |
http://www.doddsy.net/steve6_008.htm Have fun reading Anders |
#8 | |
oops!
Best regards Anders |
#9 |
Don Maurer has the most comprehensive dipole baffle width/polar response tests I've seen here:
http://home.pacbell.net/donwm/PrototypeTestResults.htm Monte Kay has tested a bunch of potentially suitable woofers for distortion and aerodynamic noise: http://www.mfk-projects.com/woofers.htm John Kreskovsky has his NaO MTM with larger woofers and a passive mid/tweeter cross-over: http://www.geocities.com/kreskovs/NaO.html |
#10 |
All interesting stuff, those measurements.
Unfortunately, I don't have neither time nor resources to do that much of DYI, that's why I have to to go with a kit/finished design. The original question came up after seeing this http://www.linkwitzlab.com/images/gr...rion-xo-eq.gif To me, th's a lot of bass equalization, +18dB at 20Hz, so I was just figuring if anyone had modded a kit/finished design using bigger woofers, likely also increasing the baffle size (i.e. depth of H-frame) to get same response with less eq, and in that way increasing the operating region of the speaker. Regards |
| 15 inch woofers: which have low moving mass? | elac310 | Multi-Way | 107 | 24th April 2012 11:11 PM |
| Four Inch Woofers Have 10 | jagster | Swap Meet | 0 | 18th April 2008 04:11 PM |
| 5 inch woofers | homertooties | Multi-Way | 4 | 20th November 2005 05:45 PM |
| Plans for 3 way using Dayton 8 inch woofers | Mos Fetish | Multi-Way | 7 | 8th July 2003 05:29 AM |
| Page generated in 0.12688 seconds (87.84% PHP - 12.16% MySQL) with 10 queries |
