Could anyone please help me with LeCleac`h cylindrical horn calculation program, I can`t get any output in the graph at all ! What am I doing wrong ? I put the all the necessary numbers in the "Horn Calculation", but when I go to the "(Half) Horn profile" nothing happens ! The only thing I got is the front view of the horn if I change the type of graphic. thanks in advance Miro |
#2 |
Posting a screen shot of your input data might help...
#3 |
Hi Miro,
¿Have you copied row 38 down to row 4039? Regards Miguel |
#4 |
Thank you guys,
Here`s the screen print of the input. I`d like to get for example the cylindrical horn. I can only get the front graph, the side profile is empty. Miro |
#5 |
As Miguel guessed, it looks like you have not set up the sheet. From the spreadsheet (translated by Babelfish:
To reduce the file, the sheet is delivered empty of these lines of calculation. To allow the calculation of all the points, it is necessary in the sheet "Horn calculation" to recopy line 38 since the line 39 jusqu'a line 4039. So, copy line 38 (or whatever the last line is) into lines 39 through 4039. Then see if it works. |
#6 |
Thank you John & Miguel a thousand times !!!!
now it works ! Regards Miro |
| Victórios new LeCleac'h horns | angeloitacare | Multi-Way | 85 | 19th February 2009 01:41 PM |
| Page generated in 0.09653 seconds (59.52% PHP - 40.48% MySQL) with 11 queries |
