#11 |
LineSource,
I've been interested in ribbons for a long time but, generally, very little interest in horns. You seem to have very specific ideas about the application of waveguides to true ribbons. What is your definition of a "shallow" horn (in terms of wavelength)? What is a "wide radius"...conical, exponential, other??? Which Geddes paper do you recommend? I'm interested enough to buy one...just one for now. Thanks, Paul |
#12 |
I am having some troouble with my Hotmail Email box, the one diyAudio uses. It tends to fill up and cut off incoming Emails.
I have received a couple of requests already for Merhaut's Horn Loaded Electrostatic Loudspeaker article. For those who might have sent a request and had my email service reject it, please comment here in this thread and I will try to contact you.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#13 |
#14 |
Mac,
Yes those do look interesting I wonder why they put a horn of radial symmetry on a rectangular source however. There has to be some mismatch here. I would have expected a smooth transition section. A "morphing transition"! That's my new patented name guys!
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#15 |
As I am reading your suggestions, I realized that my subject line was purely worded. What I am after is pattern control, and not so much increased efficiency from horn loading.
So, here are the two questions I should have asked: 1. can one "force" the sound to follow the horn countour without undue disturbance of the sound wave; and 2. what ribbon tweeter could be used given the (as I understand) high pressure in the throat? Thank you, M |
#16 | |||
Not exactly... what ur interested in is more the wave launch from the horn with respect to frequency... again as you go higher in freq the horn has less of an effect and the driver tends to "not see" a horn and act like a direct radiator... Thus the advanced "wave guide" designs like Dr. Geddes which are intended to control that aspect over the loading and efficiency aspects... Quote:
All the ribbon tweeters that I have seen loaded into horns are "loosely" loaded... not tightly coupled at all... so the pressure in the throat is limited quite a bit compared to the compression driver set up... nothing wrong with this. So you can use any ribbon you like, pretty much.[/quote] Quote:
_-_-bear
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#17 | |
To my eye these look really bad, with a sharp hard transistion from what appears to be a short parallel wall area between the ribbon and the "horn". Major diffraction going on here. Also, the ribbon design itself appears to be a copy of a recently patented (sic) ribbon that uses this slit down the center of the ribbon itself. This design was discussed in the thread here in the ESL/Ribbon area quite recently... wonder if it is a rip-off or if it is licensed? who knows, maybe these are just great... _-_-bear
#18 | |||
Dear Bear,
I have an impression that we are miscommunicationg, arguably due to my inability to express myself. Quote:
I am aware of that, but at a certain point, the driver's dispersion pattern will be equal to or greater than the angle of the horn/waveguide attached at that frequency. What will happen? If the above is misinterpretation of your thoughts, please correct me. Quote:
Thank you, M |
| Horn loaded ribbon tweeter | Mikael Abdellah | Multi-Way | 25 | 20th February 2012 08:54 PM |
| Why not a ribbon tweeter instead of a horn tweeter? | Curly Woods | Full Range | 9 | 15th July 2009 04:09 PM |
| Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate | lduarte1973 | Multi-Way | 3 | 16th June 2009 08:50 AM |
| Horn or Ribbon tweeter with fullrange | sharptouch | Full Range | 1 | 12th August 2008 04:01 AM |
| Page generated in 0.12596 seconds (80.21% PHP - 19.79% MySQL) with 10 queries |
