Old 5th November 2004, 06:37 PM   #1
Default Need help with 5" midbass cabinet size
I have made a front panel out of thick alu channel which is 6 inches wide. The cutout for the mid-bass is 122mm, so this should allow most 5" speakers. I have KEF B110s already. I could get anything that might be better, e.g.
SEAS L14RCP
Morel MW144
Focal 5K range
Jordan JX92s
Any other.........
I want the most bass that is compatible with a 5" speaker. I can go up to 30 litres. I don't know how to calculate the optimum enclosure size using VAS Qts and Fs. I don't even know what relation VAS has to the optimum cabinet size. Where do I go from here in choosing a really good mid-bass and then working out the best cabinet size to give good sound and maximum bass extension? Thank you for any help - I'm struggling here and want to get it right before cutting wood! Andy
Old 5th November 2004, 08:10 PM   #2
tiroth is offline tiroth  United States
Where do you want to cross to mid/tweet?
Old 5th November 2004, 08:46 PM   #3
Hello there - I hadn't got as far as the crossover. I was starting with choice of mid-bass and cabinet size. Hopefully I would find an existing crossover design on the Net - there are quite a few for this size of driver. I need to select a driver and a cabinet size before I can make the box! Andy
Old 5th November 2004, 09:15 PM   #4
Bill Fitzpatrick's Avatar
Generally, one does not start making the box until a COMPLETE design is chosen. You're getting ahead of yourself.
Old 5th November 2004, 09:24 PM   #5
I don't have any measurement programmes - I'm quite willing to look at one. I'm coming back to boxes after years with Maggies (moved the hifi into a smaller room) so didn't have to build any boxes. Previously I built quite a few. But I assumed that the crossover wouldn't have much to do with the bass extension and size of box - it's octaves up. Right or wrong? Andy
Old 5th November 2004, 09:37 PM   #6
If you want to look at it that way, which is not the best approach, at the very least you have to pick a woofer, which at 5" will probably be in a ported box. The box size and port dimensions come to bear. It's much easier to build a box around a woofer that it is to find a woofer to fit a previously made box.
Download a free copy of WinISD for modeling the response of woofer and box.
Old 5th November 2004, 11:14 PM   #7
Hello Bill. Downloaded the programme - I remember this years ago on the net. Looked through the 5" drivers, and the ones that seem happy in a 20 litre ported box are the Morel MW144 and the SEAS units - L14, W14 and also Monacor SPH135. So looks like I could go ahead with a ballpark figure of 20 litres. Next step is to look at some crossover designs with these drivers. The SEAS units have a nasty peak, so I'd have to have a good crossover to cope with that. The MW144 looks pretty flat and easy to use. don't know much about Monacor. Andy
SUPRAVOX 285 GMF cabinet size nirvana Full Range 7 26th January 2009 10:45 PM
Sealed sub: cabinet size?? Klimon Subwoofers 4 10th August 2006 11:26 AM
6x9 FR speakers - what cabinet size? Simpleton Multi-Way 3 15th December 2005 08:38 AM
best midbass for a horn "mini" monitor? E. Billeci Multi-Way 2 13th January 2004 06:46 PM
Cabinet Size of Satelites ??? ralph-bway Multi-Way 2 29th October 2003 09:51 AM
Page generated in 0.10352 seconds (76.25% PHP - 23.75% MySQL) with 10 queries
