diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Vifa XT25 (Probably repeated questions, but I did search first) (http://www.diyaudio.com/forums/multi-way/45061-vifa-xt25-probably-repeated-questions-search.html)
Puggie 5th November 2004 09:42 AM
I may be getting a pair of these reasonable cheap for a mini monitor project. I've read a few posts saying how the XT25 requires complex Xovers to get the best from it and one thread about glue mods to the unit. I've searched but not found a conclusive answer.
Could someone enlighten me to what this tweet needs to get the best from it? What sort of crossover (slopes and point) will it cope with and what extra filtering is required to get really good results from it. I'll probably be partnering it with 6" Peerless HDS mids, Audax aerogels, Seas or something similar, either 5 1/4 or 6 1/2 mids in very small ported boxes.
Thanks people.
Thomas 5th November 2004 10:15 AM
Hi
I posted a question just like that years(?) ago here.
My question is post #26.
Thanks to Sreten, Hugh and Navin my speakers realy 'sings'.
18dB butterworth for both drivers crossed at (not below) 2500Hz did the trick for me. The X25 needs a impedance correction network as well.
Puggie 5th November 2004 11:55 AM
Excellent, I was planning on 18dB / Oct Butterworth slopes at 2.2kHz, so I should be able to nudge that up to 2.5kHz without and grief. I'm partnering them with 8s that are good upto about 3.5kHz, so should be fine. Just remember to use a Zobel with them.
Vince35 5th November 2004 09:20 PM
Hello,
What kind of impedance correction would you use for the XT25 ?
Vincent
Thomas 7th November 2004 02:15 PM
Originally posted by Vince35
Hello,
Vincent
I can't remember the values any more. I meassured the actual values on mine and calculated the component values from there. According to the datasheet the XT25 have a impedance peak arround 550Hz. I think you can rely on the values given.
Link to online calculator:
http://www.carstereo.com/help/Articles.cfm?id=23
madinoz 16th November 2004 04:12 AM
I wouldn't start doing physical mod's to the XT25 unless you saw some burning need to.
I have used this tweeter a number of times. I did use it with a 2nd order crossover at about 4000hz to good effect. The requirement for a steep crossover slope would probably only come into effect if I was building a speaker required for high SPL listening levels.
The impedence correction filter should allow the use of a lower order crossover and will clean up the tweeter's response.
PS Listen to the XT25 dirctly on axis when testing the crossover, the off axis response falls off quite sharply!
Resources saved on this page: MySQL 18.75%
