I'm new to diy, and home audio in general. I've started to build a home theater and want to add a center channel and sub soon.
I have read a lot on threads on here but am not very familiar with ribbon tweeters. Well I really have never heard one, and dont know of any audio shops near me that sell speakers with ribbon tweeters. Obviously this might be difficult, but if possible could anyone explain how ribbon tweeters sound. (remember I am a newbie, not too harsh) I'm a member of elite car audio and have been referred to a book called the Loudspeaker Design Cookbook to help teach me about enclosure design and passive crossovers. Is this a good book to purchase? |
#2 |
Banned
Dickason's book is as good as any and better than most. Ribbons have extremely fast transient response due to their very low diaphraghm mass.
#3 |
I'm going to order the book hopefully tonight. Although I have little experience, do you think it will be difficult for me to build a simple passive crossover?
Are ribbon tweeters good for imaging? From what I have read this is a yes, is that true? Do ribbon tweeters need a seperate enclosure as to not be effected by other drivers, similar to dome tweeters? Due to the high effeciency of a ribbon tweeter I'm guessing they are very detailed. Can ribbon tweeters sound staticky? Thanks, Josh |
#4 |
Speakerholic
Josh,
A simple passive XO is easy. A good XO is a lot of trial and error. Ribbon tweeters are good for imaging. Ribbons are self contained and do not normally need a separate enclosure. What do you mean "like dome tweeters"? High efficiency? Bill said they have fast transient response. Quite different from high efficiency. They are usually not very efficient. Staticky? Only if the source is staticky. (I like the word by the way) Cal |
#5 |
Here is my situation, Steely Dan records his albums with very good SQ correct? Especially with a dvd cd. And obviously I shouldn't judge my speakers like this, but when I am very close to my tweeter there is some static.
Is it still preferable for a ribbon to have its on box, this is inside the enclosure if I'm not being clear enough. "what do you mean like dome tweeters?" Well shouldn't dome tweeters have their own compartment so that other speakers do not interfere with the tweeter's sound? I have read a few articles about properly building a good crossover and i think i can understand how hard it is. What do most of you cross over your mids and highs at? What I have read is that you should use test tones to figure out where to set the crossover. But what is an average, for 6.5" or 7" midbass? Maybe I should search this topic, but what size midrange do you all prefer for a 2way? Thanks, Josh and sorry I am horrible as spelling. |
#6 | |||
I am also fairly new to DIY, so keep it in mind that if somebody comes along and disagrees with me they are probably right |
#7 |
The static, sounds similar to snow on a tv. It seems to me that it is not necessarily pops or crackles, the only way I can describe it is tv static. The "static" seems to be at the same volume no matter what volume the amp is on. So at lower volumes the static is more predominate, at higher volumes it is much harder to hear, but seems to still be there, at this constant volume.
HeatMiser, complete opposite answer i wanted to hear about midrange drivers How do I have a steeper roll off? How do I know which cap will have a steeper roll off? (I'm hoping roll off is the right word to use in this situation) where are good places to order good caps and inductors? I'm ordering the Loudspeaker design Cookbook 2morrow so after I get it I doubt I'll have as many stupid questions. Thanks, Josh |
#8 | |||||
Guess I'll jump in again since nobody more knowledgeable has taken notice yet.
All that said, there are probably lots and lots of 2-way speakers that place the crossover in the 2500-3000 range, but assuming a crossver point in that range will somehow just work would be a tragic mistake. There is usually a lot more to it than that. Quote:
#9 |
Thanks heatmiser
I'm guessing I can do a search on good caps. I can't think of any more questions right now Thanks, Josh |
#10 | |
Speakerholic
Do you know what a Steely Dan is? If not, ask your wife/sister/girlfriend. But do it in private. I'll give you a hint: It's long, cylindrical and makes a buzzing sound. Sorry, just couldn't resist. Cal |
| Some Quad els57 questions! - Novice Questions! | Fanuc | Planars & Exotics | 13 | 5th December 2007 09:26 AM |
| PSU for QSC amp questions | rkc7 | Parts | 5 | 10th November 2005 05:18 PM |
| Last questions about this | Madmike2 | Multi-Way | 9 | 13th June 2005 11:12 PM |
| Questions, questions, from newb DIYer | Phatman91624 | Multi-Way | 41 | 3rd August 2002 02:52 AM |
| Page generated in 0.14721 seconds (80.29% PHP - 19.71% MySQL) with 10 queries |
