Old 30th October 2004, 02:39 PM   #1
gpc is offline gpc  United Kingdom
Default audax home theatre front
Hi all, great forum
I am a bit of a newbie to building speakers this is to be my first project (done hopefully correctly)
I was thinking of changing the audax home theatre main speakers to a floorstander and need a bit of advice.
would i need to alter the original crossover design?
I have played with WinISD a bit could someone take a look at the transfer function
the port comes out at 8.2cm dia 7.99 length, the resonance is 2150.2Hz. What effect will this have on the sound? should i try to get a different resonance?
Ian
Old 30th October 2004, 04:07 PM   #2
Changing the bass/mid to a different box will not affect the crossover to the tweeter. Any change in box size, type, etc will be under 1,000 Hz, in fact under 500 Hz, so the tweeter crossover range is not involved at all.
It seems to me that a cubic foot and a half is a lot of volume ot get down to a 47 Hz cutoff, but if you are willing to use a box that size for convenience sake, go ahead.
The port resonance of 2150 will not be affected. Your port will have maximum output at 48 Hz, be 12 dB down 96 Hz, 24 dB down at 192 Hz, etc. By the time you hit the pipe resonance of 2150, you'll probably be well over 100 dB down from the midpoint!
So relax.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 30th October 2004, 04:16 PM   #3
Something is wrong.
Looking at your Thiele-Small specs in your graphic, I see the Qts is 0.397, and the Fs is 48.5.
Such a speaker would do well in a ported box approximately equal to it's Vas, and tuned to it's Fs, or close.
Instead, your box is twice the volume of your Vas. You should show a "boom" in the response. Yet, the response is flat.
Something is wrong. For flat respnse, your enclosure should be about 24 liters and the tuning should be about 48 Hz.
Let me check to see if your port would tune a 48 liter box to 48 Hz.
-Anonymous
Old 30th October 2004, 04:18 PM   #4
pinkmouse's Avatar
Just a quick point, but if you haven't already got the drivers for these, check you can, as Audax have given up on diy sales in favour of mass market OEM sales. I would hate you to do all this work and not be able to build anything at the end of it...
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 30th October 2004, 04:24 PM   #5
I use an older, simpler version of WinISD which does not deal with Transfer Function. So I will forego discussing that.
If you want to know about Transfer Function for a ported box, I will refer you to Thiele and Small's papers on the subject-there is a site where a diyAudio member, richie00boy, generously lets you download them for free.
http://www.richie00boy.pwp.blueyonde...pers/index.htm
However, going by the Thiele-Small numbers as listed:
Volume of box: 25 liters
Tuning: 48 Hz
Vent: 8.2 cm diameter, 21 cm length.
You have Thiele's "Classic" Bass Reflex, and it should serve you well.
-Anonymous
Old 30th October 2004, 04:51 PM   #6
thanks guys
Pinkmouse-Ipl acoustics in uk still have the drivers listed, i'll give them a ring on monday to check
kelticwizard- it seems if i just alter the box size in winisd the response stays quite flat upto about 60l
with this being an mtm does this mean that you can double the vas because of 2 drivers?
still intent on making some nice slim floorstanders would i be better off splitting the box into 2 halves to get down to 25l. the bottom half basically a stand
Old 30th October 2004, 05:10 PM   #7
By the way, what is the model number you are using? I'd like to model it myself.
Going from 48 to 60 liters is a 25% difference. It should "boom" maybe only a decibel or two.
Did you model this using two drivers? That would explain the difference.
If WinISD or any program has a provision for number of drivers, you don't have to do that. If you use a different program and it has no provision for different numbers of drivers, then you must double Vas.
If the thing is an MTM, you will use the full 48 liters, so you won't have to do that. Slim floorstanders are nice, aren't they?
by the way, using two woofers will mean the vent should be originally as modelled, 8.2 cm diameter, 8 cm long.
-Anonymous
Old 30th October 2004, 05:29 PM   #8
the model no. is AP170ZO ipl sells these for £25 which seems reasonable
http://www.partsexpress.com/pe/pshow...number=296-165
yes model with two drivers the winisd im using lets you select upto 10 drivers
oh and the tweeter
http://www.partsexpress.com/pe/pshow...number=276-152
basically i wanted to start off with a kit that was already well designed for my first build, but then thought I wonder if these would work well in a tower lol.
I could then make the towers the right height etc.. for my sitting room
the kit is this one
http://www.madisound.com/audaxhometheater.html
Old 30th October 2004, 05:48 PM   #9
had another play with winisd and 54l seems to look good aswell
Thanks again for your help
Ian
DIY Home Theatre luckybob Multi-Way 4 25th May 2006 06:19 AM
Home Theatre bhg41088 Multi-Way 4 16th August 2004 01:32 PM
Audax Home Theatre Again crispy Multi-Way 4 19th February 2002 06:40 AM
Page generated in 0.11594 seconds (78.46% PHP - 21.54% MySQL) with 11 queries
