I'm looking for possible low cost full-range drivers [aren't we all?
This is a tough driver that goes up to 15K and is designed to be abused. Madmark??????!!!!! http://www.partsexpress.com/pe/pshow...number=295-010
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#2 |
Haven't done any mods, but FWIW I did both a max flat ML-TL and an extended BW version using some series R for it some time ago and the former sims aneochoically flat to 80Hz/90dB/2.83V/m, with the latter to 60Hz/~87.5dB/2.83V/m, but I don't know if the dude ever built either so don't know how accurate they are.
Of course, at least dual drivers is required to keep distortion ~reasonable once you move out of the nearfield. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
RCA,
That frequency response graph looks way too ragged between 3K and 10K to make a good FR driver. The search goes on.....
Everyone has a photographic memory. It's just that most are out of film. |
#4 | |
John, Out of the box stock I'd totally agree but I was thinking the bumps might be tamed by the modifications I spoke of. I was looking at Tang Band driver response plots on the PE site and those 3 and 4" drivers don't look any better quite frankly.
#5 |
Smoothing out a peak is one thing, but that big dip at 4khz is what turns me off. The whole point of using FR drivers is to minimize things in the signal path. You really have to get out to at least 10khz and that's still only "wide range" and a super tweeter is needed on top. Any less than 10k and it really starts to sound muffled, at least to my ears.
#6 | |
John, Everything you say is true. That hole at 4 KHz looks like a mechanical suck out that I thought modifications could cure because it is so blatant and high-Q that it must be one specific thing causing it. Anyhow, your points are exactly why I'm asking first and not ordering any just yet Maybe I was just enamored by such a huge magnet on a small speaker for the low price!
#7 |
GM,
Thanx for the input. Too bad you didn't hear the things.
| SEAS X1-08 Exotic F8 8" full range driver | jackfish | Full Range | 6 | 16th March 2009 09:48 PM |
| Akai 3"full range driver | gaborbela | Swap Meet | 15 | 14th November 2008 10:10 PM |
| 3" or less full range driver, no filter | notacop | Full Range | 32 | 30th June 2008 04:30 AM |
| RE: Rare full range driver DUODE 12" | movingcoilguy | Full Range | 8 | 3rd September 2007 10:51 PM |
| UTAH 8" Full range driver | Kazik | Full Range | 1 | 22nd April 2007 03:19 AM |
| Page generated in 0.10862 seconds (73.96% PHP - 26.04% MySQL) with 10 queries |
