Hope someone can share the ideas how to go with the rise on this mid/woofers 600-1400Hz range.
What tricks are there to deal with such resp anomalies. The woofer is originally from Dynaudio Acoustics BM5 studio monitor and in it's original crossover it has only baffle step compensation with 0.6mH in parallel with 1.1 ohm resistor. No crossover as such at all and no compensation for peaks either. My plan is to use this woofer with Seas Millennium tweeters and if I can pull it off then to cross them around 4kHz. If someone has experience/ideas what would work best here please comment. Ergo |
#2 |
Why please cut your woofer to 4000 Hz with tweeter SEAS millenium?
It is a tweeter which at a frequency of rather low resonance. It is necessary benefitted from it Me I would be you, I would leave the filter like this, and I will apply a NOTCH to the boomer for gummed this imperfection. It would be necessary to test a circuit RLC//, assembled in series on the boomer. To test that (3.3R + 68 MF + 0.47 mH) Hold me with the current for new measurements
| Freq resp measurements on the Apex Jr 3" M&K twin cone? | Brisso57 | Multi-Way | 0 | 11th October 2007 08:38 PM |
| Baffle Step & Freq. Resp. Combiner Help | 69stingray | Multi-Way | 0 | 24th May 2007 03:14 PM |
| 110 hz freq resp dip | MichaelJHuman | Subwoofers | 5 | 16th September 2005 09:28 PM |
| ATC Dome Mid Freq Resp -click here- | amo | Multi-Way | 0 | 15th July 2003 12:43 AM |
| putting sub in smaller box, and making an eq to compenste freq resp. | mikesimas | Multi-Way | 1 | 15th May 2002 11:22 AM |
