using passive crossover before amps to active biamp?
Old 28th October 2004, 10:18 PM   #1
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
Default using passive crossover before amps to active biamp?
hello everyone. im going a little slow building my MOX active crossover, so i had a thought. i already have matched stereo amps to passively bi-amp my front speakers. i was curious if i can remove the crossovers from the speakers, put them BEFORE the amp, and use them in place of the active crossover im building. would i really benefit from this? my speakers are pretty inefficient and power hungry (magnepan tympani 1D's).
i already have an outboard box i could use that will house the active crossover... so, if i just toss the guts of the current passive crossover in there, will it give me some of the benefit of the active crossover?
thanks!
Old 28th October 2004, 10:39 PM   #2
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
Forget it - won't work.
Old 29th October 2004, 12:32 AM   #3
cowanrg's Avatar
any reason why?
magnepan actually sold early pairs of their tympani's with EXACTLY that. its a little box that is passive, has one pair of RCA's in, and two pairs out. it has full range in, and low and high out... it goes between the pre-amp and the amps. what is so different about that?
Old 29th October 2004, 12:38 AM   #4
Because for the crossovers to work as they should the load on them needs to be the same as the speaker, 8 ohms or so. But if you load them that way your preamp won't be able to drive it.
Old 29th October 2004, 12:52 AM   #5
cowanrg's Avatar
interesting. if there any way to make a passive xover that can be driven this way, or does it have to be an active one?
Old 29th October 2004, 01:51 AM   #6
BobEllis is offline BobEllis  United States
BobEllis's Avatar
http://www.t-linespeakers.org/tech/f...ssiveHLxo.html
Old 29th October 2004, 02:35 AM   #7
cowanrg's Avatar
cool, thanks! if i remember correctly, my speakers only have a 6db/octave 2-way crossover. so doing a simple passive line level xover would be easy and cheap. ill look into it. thanks again.
Old 29th October 2004, 02:45 AM   #8
cocolino is offline cocolino  Germany
cocolino's Avatar
This kind of RC-filters do not allow for steep(er) filter slopes as with CL-filters used in most "usual" passive crossovers.
It is possible though to use CL- filters in passive line level circuits when the load is lower than the 5k to 10kOhm loads as presented in the RC-filters from the link above (or as it is a common load value in many active crossovers too).
With let`s say 600 Ohms load the necessary big inductor values (up to about max. 100mH) for the LC-filters are still avaiable as small ferrite core inductors.
The load presented by this kind of passive filters may be to low to be driven properly by some preamps. with a wimpy output stage but with a suitable buffer (BUF634, LT1010 etc.) which can provide some "juice", this isn`t a problem.
Works fine!
Christoph
STEAL the BEST - INVENT the REST
using passive crossover before amps to active biamp?Hide this!Advertise here!
Passive or Active Crossover before amp Zero One Parts 1 6th May 2009 01:17 PM
Changing a passive crossover to active soundengine355 Multi-Way 101 18th August 2008 05:50 PM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 07:16 PM
subwoofer crossover passive and active yikchean Subwoofers 3 3rd December 2006 03:18 PM
biamp and active crossover arthur Solid State 3 7th May 2003 11:29 PM
