Old 28th October 2004, 01:43 AM   #1
Default Field coil wiring question
I'm trying to rehab an old Silvertone & here's the problem: the amp schematic requires a 5 wire speaker; 2 field coil leads & 3 voice coil leads (center tapped). The speaker I've gotten only has 4 leads (no center tap on the voice coil). Is there any way to make this work?
Old 28th October 2004, 07:53 AM   #2
Brett's Avatar
Default Re: Field coil wiring question
At a guess, don't use the CT? If the FC is AC supplied and you get hum in this config, try it with DC on the FC.
I've just got a few Jensen FC speakers and am keen to play with them.
Old 29th October 2004, 12:46 AM   #3
Default My bad
It looks like the speaker I have (4 wire) is for a single ended (1 output tube) amp, while the Silvetone I'm doing is push pull (2 6K6G output tubes). I'm thinking I can just go w/an output transformer for the voice coil & be done with it?
Old 29th October 2004, 07:02 AM   #4
Brett's Avatar
Default Re: My bad
It shouldn't make a difference. Take what you have, and wire the FC up, then connect the speaker without using the centre tap. You don't need anything else, let alone to replace the OPT's.
Has anyone DIY a Field coil? OzMikeH Full Range 18 16th November 2010 01:56 PM
The field coil revisited... Rocky Full Range 2 16th May 2006 02:56 PM
Looking for jensen field coil Kris9999 Multi-Way 2 10th February 2006 04:31 PM
Question to Supravox /Fertin Field Coil Users xcortes Full Range 1 25th January 2005 06:14 PM
Dual voice coil wiring question bigshooter13 Multi-Way 18 4th October 2003 09:18 AM
Page generated in 0.07511 seconds (76.32% PHP - 23.68% MySQL) with 10 queries
