Old 27th October 2004, 02:06 AM   #1
Hybrid fourdoor's Avatar
Default WinISD Pro XO Calculator...gotta a bug??
Whenever I use WinISD (0.50a6) and use the 2nd order passive XO calculator, it gives different values for HP and LOW....instead of just fliiping them, like every other calculator does. Just wondering if Linear team is using a different equation than most poeple, or if there is something wrong...
Examples
8 ohm tweeter at 2000Hz
C2: 7.03uF
L2: 0.45mH
8 ohm woofer at 2000Hz
C1: 14.07uF
L1: 0.9mH
C2: 4.98uF
L2: 1.27mH
Same values, just connected differently
So what gives? Is this one of those things like in some circuits where you have a cascade of the same circuit, but one will be a multiple of 10 of the other, but it still works out the same?
I enjoy my organic shapes.....
Old 27th October 2004, 02:18 PM   #2
jomor is offline jomor  Greece
jomor's Avatar
Perhaps the author of the program could enlighten you, on the WinISD forum:
http://linearteam.proboards12.com/in...i?board=winisd
Gotta show it off! davidlzimmer Chip Amps 20 6th July 2006 10:38 PM
You gotta see this! dshortt9 Everything Else 4 9th August 2004 05:48 AM
you gotta laugh theChris Everything Else 1 11th March 2004 06:13 AM
gotta start somewhere---- zx3chris Introductions 4 17th December 2002 12:31 AM
Page generated in 0.07809 seconds (71.25% PHP - 28.75% MySQL) with 10 queries
