looking for good mid woofer to use with Ribbon Tweeter.
Old 26th October 2004, 11:30 PM   #1
samsagaz is offline samsagaz  Argentina
Default looking for good mid woofer to use with Ribbon Tweeter.
hwy guys, i already buy an AurumCantus G2Si Tweeter and i want to buy 2 Mid drivers to create an MTM center box.
the characteristics of the tweeter are
Response 2khz - 40khz /-3db
Sensitivity 96db 1w/1m
Flat 6 ohm impedance
30w power handling
Fully shielded
110mm circular black face plate
can someone tellme an good Mid to use with this kick *** Tweeter?
thanks
Old 27th October 2004, 01:42 AM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
How big?
planet10 needs your help:
Let's help Ruth and Dave
Old 27th October 2004, 06:12 AM   #3
4, 5, 6 "
will be 50-150 bucks each one
Old 27th October 2004, 06:36 AM   #4
Will is offline Will  Malaysia
Fostex FE206 perhaps ?
Old 27th October 2004, 06:58 AM   #5
u tested it?
u heard it?
the Sensitivity looks nice.
i was thinking to buy the Eton 4-300 but the Sensitivity are so bad.... but the response curves are great
what do u think?
http://www.eton-gmbh.de/ShowPage.php?PId=20&LangId=0
and one more question, if my tweeter work at 96dB but its 6ohms instead 8, like the mid, the tweeter loose 3dB?
Old 27th October 2004, 03:55 PM   #6
Luke (Uof Iowa) is offline Luke (Uof Iowa)  United States
Luke (Uof Iowa)'s Avatar
Look at the Eton 5-880, which is used in the GR Research design that has an AC tweeter.
Old 27th October 2004, 05:25 PM   #7
budwiser is offline budwiser  United States
I may have an older model of the 4-300 laying around. The ones with the yellow kevlar cone. Used them in a small speaker setup. Sounded good.
Old 27th October 2004, 06:18 PM   #8
yes i was thinking to buy the 880 for the Front speakers but i think that dont will be so good, it have 87dB of Sensivity
and my tweeter 96!
i think that dont will be an good choice low my tweeter 9 dB!
Old 27th October 2004, 07:03 PM   #9
4real is offline 4real  Netherlands
I used the G2si with two Monacor 135KEP woofers. The result is quite nice.
Old 27th October 2004, 07:10 PM   #10
yes but is 89dB of sens too i want more sens dont want to lower my tweeters (i think that its not good)
looking for good mid woofer to use with Ribbon Tweeter.Hide this!Advertise here!
Dipole Ribbon tweeter isolation from dipole mid-woofer array Bent Planars & Exotics 8 29th March 2015 09:45 AM
Why not a ribbon tweeter instead of a horn tweeter? Curly Woods Full Range 9 15th July 2009 05:09 PM
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 09:50 AM
good ribbon tweeter caz Multi-Way 5 22nd May 2004 02:08 AM
Titanium tweeter vs Ribbon tweeter goldyrathore Multi-Way 14 17th May 2004 08:21 PM
