Old 27th October 2004, 06:41 PM   #11
4real is offline 4real  Netherlands
Send a message via ICQ to 4real Send a message via MSN to 4real
I don't think you'll get mid's with 96 dB together (it more like 94 dB, but still), specially not if you want a little bass!
Old 27th October 2004, 06:45 PM   #12
Originally posted by 4real
I used the G2si with two Monacor 135KEP woofers. The result is quite nice.
Or the SPH-165KEP.
Old 27th October 2004, 06:49 PM   #13
5th element's Avatar
Yes you will loose 3dB sensativity. Not exactly loose but when I measure a SSD2905 6ohm tweet and a peerless 8ohm midbass together I need to boost the tweeter by three decibels in the simulation program to match the measure combined response.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 27th October 2004, 08:29 PM   #14
bser is offline bser  United States
You also want a mtm you said so you don't have to have a woofer with a 93+ sensitivity since you will be using 2 mids for the 1 tweeter.
Old 27th October 2004, 10:20 PM   #15
ok, but, how many dB i gain using 2 Mid wooferS?
3dB?
Old 28th October 2004, 12:19 AM   #16
5th element , how u measure it? using an mic?
Old 28th October 2004, 02:24 AM   #17
Luke (Uof Iowa)'s Avatar
Doubling the cone area will gain approximately 3 dB. However, they will also have a lower impedence in parallel, so it will be even higher. I have not heard the GR Diluceo, but I doubt it would disappoint from what I have heard of it.
Old 28th October 2004, 04:50 AM   #18
If you want high efficiency drivers look at PHL. I'm not sure all the places that sell them but you can try here:
http://www.e-speakers.com/ I've never bought from the company but there is plenty of information on their site that may be of use to you. The only problem with PHL, is that they may be a little over your budget.
Old 28th October 2004, 05:00 AM   #19
trans192
yes they looks nice, bue its too much, 96dB is too much i need 91-93 dB because if i use 2 Mid ill get an gain of around 3-4dB.
the eton curves are great, but the sens is not so good.....
sorry for my english
Old 28th October 2004, 06:47 AM   #20
http://www.e-speakers.com/pdf/PHL1240.pdf
This driver seems to fit your criteria -
16 ohm (good for paralleling)
42fs
93 db sensitive
$129 ea
the down side is a Qts of only .23
http://www.e-speakers.com/pdf/audiom-6wm.pdf
This driver also seems to fit your criteria -
Morel H6.1 from www.madisound.com
I have used morel drivers in the past and really liked them.
H6.1 6" Poly cone woofer
8 ohm, 40 Hz Fs, .32 Qts, 30 Vas, 150W, 91 db/1M/2.83 V, $90.00
Why not a ribbon tweeter instead of a horn tweeter? Curly Woods Full Range 9 15th July 2009 04:09 PM
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 08:50 AM
Dipole Ribbon tweeter isolation from dipole mid-woofer array Bent Planars & Exotics 5 21st May 2009 12:10 PM
good ribbon tweeter caz Multi-Way 5 22nd May 2004 01:08 AM
Titanium tweeter vs Ribbon tweeter goldyrathore Multi-Way 14 17th May 2004 07:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
