I've tried several crossovers using these two drivers in a .5 cubic ft rear vented box. I always end up with a bright and forward sounding speaker when using xovers that model well on paper. Things end up very detailed (good thing), just too unnatural sounding (bad thing). Believe it or not, the xover I've liked the best was a 1st order .47mh on woofer and 6 uf cap on the tweeter with a 7 db l-pad on the the tweeter. It sounded fat and full of life with laid-back vocals and highs while maintaining most of the detail. However at mid to high volumes things got nasty sounding. I'm assuming this is mostly due to a struggling tweeter. Any advice would be a great help. Please feel free to post or email me directly.
IB |
#2 |
Even using a 1st order the tweeter should not be struggling as it has a very low Fs. 7dB on the L-pad sounds too much and should require about 4dB IMO.
When calculating the xo values use the actual impedance at the crossover frequency and not the nominal value. A measured impedance is best if you have the measuring gear but the manufacturers graph would give a better value than the nominal and a good starting point. For example, 1st order at 3000Hz xo, the tweeter is 5.3ohm and the woofer is 12.6ohm from the manufacturers graphs which would give 10uF on the tweeter and 0.67mH on the woofer. You could search around for xo's for the same drivers and try that. If you can't find any try an assymetrical crossover with a 1st order on the woofer at 3000Hz and a 2nd order on the tweeter at 3400Hz as these usually work well IMO. A quick calc gives approx Woofer 1st order: 0.66mH Tweeter 2nd order: 4.4uF + 0.5mH (LR) or 6.2uF + 0.35mH (BW) But with all crossovers, 5% calculation, 95% testing and fine tuning. Have fun and if you're game can always try a series xo. |
#3 |
#4 |
Could try a lower attenuation on the tweeter (as suggested above) and creating a trap to lower the resonance of the tweeter at it's fundamental resonance ( L-c-r in parallel to the tweeter). This should clean up the problem with the sound distorting at higher levels.
| help with vifa d27tg-45-06 replacement | MC Dig | Multi-Way | 14 | 8th April 2009 12:38 AM |
| WTB: Peerless 6.5" CSX 850122 | Nm2285 | Swap Meet | 1 | 18th October 2006 07:24 PM |
| Peerless #850122 and #850108 | arcturus | Multi-Way | 2 | 17th November 2005 05:58 AM |
| 850122 designs | bhg41088 | Multi-Way | 0 | 31st July 2004 01:12 PM |
| Vifa D27TG Crossover | nrgy | Multi-Way | 9 | 15th April 2004 07:58 AM |
| Page generated in 0.09958 seconds (69.20% PHP - 30.80% MySQL) with 10 queries |
