Old 24th October 2004, 02:54 AM   #1
wigginjs's Avatar
Default Center Channel
I was hoping to get some feedback for a design I have been working on. It's a center channel speaker for my home theater. Attached is a sketch of the front baffle and the crossover I was thinking of using. It's a horizontal MTM using two of the new Dayton Reference 6" RS150S-8 and a Seas 27TDFC tweeter. The enclosure is approximately 1ft^3 (28L) tuned to 48Hz. I'd particularly be interested in feedback on my crossover as I have very little experience designing passive networks.
The Four Chairs
DIY Home Theater
Old 24th October 2004, 02:55 AM   #2
wigginjs's Avatar
Here is the xover...
The Four Chairs
DIY Home Theater
Old 24th October 2004, 12:35 PM   #3
Banned
The biggest problem with centers is the usual side by side driver mounting, often required by the space available. Your box would do much better if the midbasses were mounted with their frames touching and the tweeter mounted above instead of in between.
Old 24th October 2004, 11:25 PM   #4
LineSource's Avatar
Default Is beaming a desirable quality for center channel??
Personal Experience: For a center channel, some beaming is desirable.
Large diameter coaxial drivers have sounded best for center channel.
Started with old Jenson Tri-axial. Current center is Lambda TD15S with a coaxially mounted Seas Millenium, LR6 @1000Hz. Trim Millenium front plate, metal tripod coaxial mount in front of TD15S
Old 25th October 2004, 04:21 AM   #5
paulspencer's Avatar
Motion, you have a dedicated theatre don't you? In this case you could make it a tower speaker and orient it vertically. From a looks point of view, I think it would look better if it were a bit less chunky - longer in the longest dimension and not as wide.
If it MUST be oriented horizontally then perhaps you should consider:
* 3 way with a small midrange with a tweeter above
* a coax driver like the 6.5" seas with a matching midbass next to it
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 25th October 2004, 10:02 PM   #6
wigginjs's Avatar
I understand the driver positioning isn't optimum. I was hoping to get some comments of enclosure size/tuning frequecy and especially the crossover design. Any ideas or comments regarding those?
The Four Chairs
DIY Home Theater
Old 26th October 2004, 01:48 PM   #7
4real is offline 4real  Netherlands
Send a message via ICQ to 4real Send a message via MSN to 4real
why not make a 2.5-way design with the same units and configuration. You do not have the problems of a normal horizontal MTM, and still have the looks of a normal center. Also, you don't need to make a baffle step compensation circuit
I still prefer the vertical MTM...
Need center channel help Ryan_Mc Multi-Way 0 12th February 2009 03:36 AM
center channel?? wicho Multi-Way 1 25th October 2008 01:01 AM
Center channel with one mid Buzzy Multi-Way 11 17th October 2008 03:52 PM
T-amp for Center Channel? atleer Class D 3 6th August 2007 04:56 PM
center channel sidd_raj2002 Multi-Way 14 4th December 2004 02:41 PM
Page generated in 0.09659 seconds (75.27% PHP - 24.73% MySQL) with 11 queries
