Old 23rd October 2004, 02:59 AM   #1
muhy3 is offline muhy3  Australia
Send a message via AIM to muhy3 Send a message via MSN to muhy3 Send a message via Yahoo to muhy3
Default Attenuate?
I am designing my first 2-way speaker (after the success of my subwoofer using the 12" peerless XLS). Anyway the tweeter is 6dB more sensitive than the mid-woofer. In order to match the woofer and tweeter, would I have to attenuate the mid-woofer or the tweeter?
Thank you.
There used to be a time, when penguins filled the sky!
Old 23rd October 2004, 12:33 PM   #2
Grahamt is offline Grahamt  Canada
Grahamt's Avatar
You can only bring down the tweeter sensitivity. You can use an Lpad, you may also want to compensate for baffle step loss. That is about all the help I can give, someone more knowledgable maybe can be more specific.
Old 23rd October 2004, 06:17 PM   #3
RJ is offline RJ  United States
1: You can add another Woofer and parallel it. That'll raise the db by 6
2: You can by an L-Pad resistor and install it in the Tweeter circuit.
3. I buy a bunch of 1,2,3 & 4 ohm audio grade resistors & tweak it that way.
L8'er RJ
Old 24th October 2004, 01:53 AM   #4
Thnx doodz!
How to attenuate the alt kerrysun Full Range 1 30th October 2008 09:12 AM
Attenuate tweeter level by 2 db bastek Multi-Way 8 27th May 2008 10:08 PM
how to attenuate aleph p 1.7 elviukai Pass Labs 13 9th March 2007 05:47 PM
how to attenuate a speaker as a mic? newmz Instruments and Amps 2 14th February 2007 05:29 AM
tweeter - How to attenuate or reduce efficiency? Nordic Multi-Way 3 29th November 2006 11:51 PM
Page generated in 0.08197 seconds (64.32% PHP - 35.68% MySQL) with 10 queries
