I am looking for a complete DIY system (except source) for mainly listening to classical and jazz music in a relatively small room. I think about a tube amplifier and a sensitive loudspeaker (like every Fostex based one). My budget is max 1000 USD but I think it is not impossible to make it.
I really like the philosophy behind ptsoundlab.com, but there are too many variations there and everything is in french. For that kind of music there was an advice: a 11W integrated KT88 amplifier and a Fostex FE208ES based loudspeaker (almost full range driver) http://ptsoundlab.com/sectubes/schem...sn7kt8811w.htm http://www.ptsoundlab.com/secenceint.../fe208esbh.htm The other interesting things I came across were the ORIS horn based speakers using AER drivers. The entry level DIY KIT is about 450 USD, but I know nothing about how good does it sound. The other idea is not a DIY speaker but a very cheap commercial one, the Magnepan MMG W. It won a Blue Moon award at 6moons and it is only 300 USD. It says nothing about how difficult is it to drive with a SE tube amplifier. http://www.diy-systems.com/ http://6moons.com/audioreviews/magnepan/mmgw.html OR What do you think about buying a Stax SR-404 and building Kevin Gilmore's Blue Hawaii hybrid amplifier. I know nothing about the KGBH but once I heard a Stax Classic system and it was really musical. |
#2 | ||
Then you would be well on the way to something _magical_ for a relatively low cost. Few things sound as good to me as front horns. I haven't heard the Oris horns but know several people that have. The Oris are well thought of, I'm using Azurahorns which are similar - but with a different flare and larger. It would be a minor challenge to match a sub but that is doable also. Put that with a homebrew 2A3 amp and you're well on the way to reaching your goal and getting maximum sound for your money. Regards Ken L
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day |
#4 |
Do you think it is possible to DIY an electrostat with amp under 1000$?
At the moment I am thinking of a 2A3 and a very efficient horn speaker. I can choose between two rooms: one of them is 3 x 3 metres, the other is 6 x 6 metres. What do you advice: a 2A3 or a cheap 300B based amplifier? Are ORIS horns in this budget or it is better to do some back loaded horn or TWQT? |
#5 |
The Oris doesn't seem like a very good choice if the total budget is $1000. To the 427 Euros, don't you need to add the drivers, plus bass drivers, cabinets, and another amplifier? And you still haven't paid for your main amplifier
#6 | |
Do you know any "best value" DIY high efficient speaker? What do you think about this japanese design using FE208ES? http://world.altavista.com/babelfish...a%2fpag9-1.htm |
#7 | |
Get some 'stats together, a nice little 25-35 watt classic design tube amp (you've got $800 left in your budget!) and those strings will sound unbelievably good.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#8 | |
You might like to look at the EL84 amp from diytube.com. Good luck! I'm sure you will get lots more opinions |
#9 |
JohnR:
Yes, I've heard many opinions that Fostexes are not the best. There is a local driver builder company, who produces full range drivers much better than the Fostexes for the same price, I might pick from their drivers. There is a link, the page is in hungarian but the specs are the same. http://www.sonido.hu/1.htm http://www.sonido.hu/info/sfr200.htm SY: I have found some DIY ESL link, but it looks more complicated to me than a full range driver loudspeaker. Is a crossover and a sub always needed for ESLs, or there are some alternatives (like almost-full-range)? |
#10 |
Well, you've got a small room and you're not listening to heavy metal. A reasonable size panel (say, 80x120cm) will do nicely without a sub. Running a panel full-range, no crossover, has a certain purist appeal.
Yes, there's some complication, but it's more on the order of gluing together fiddly bits than trying to debug complex circuits. ESLs are simple devices. Take a look at Sheldon Stokes's web page for his version. And the Roger Sanders book, though deeply flawed, has excellent practical advice on building panels.
| Great classical Music ? | Space1 | Music | 3 | 2nd July 2009 06:59 PM |
| Tube system for classical audio | Phoenix70 | Tubes / Valves | 33 | 26th April 2009 05:09 PM |
| Eq Of Classical Music Instruments | oldheathkitphil | Analogue Source | 5 | 10th April 2008 10:05 PM |
| Classical music anyone? | classicchic79 | Music | 1 | 18th April 2004 08:20 PM |
| Is recorded classical music dead? | SY | Music | 32 | 4th February 2004 03:58 PM |
| Page generated in 0.14056 seconds (76.71% PHP - 23.29% MySQL) with 10 queries |
