Old 22nd October 2004, 03:33 AM   #1
Default Bigger than needed pa enclosures.
Hello all audiowizards.
Looking at conventional PA systems one often sees fairly big enclosures for the "top" part wich usually contains one or two 12 or 15s and then a compression driver.
Now theese speakers usually dont play the bottom 120 hz or so since they usually are actively crossed to match one or more subwoofer.In thereory they could be pretty small...
I wonder are they so big so they CAN play deeper if such a signal is fed to them, or is there some kind of headroom space in there to increase spl?
Or why are they made bigger than they play?
If a speaker is playing only the Midbass and up why not make it smaller?
thanks for reading.
H.Honda Chico CA Land of the fooled
Old 22nd October 2004, 08:50 AM   #2
OMNIFEX is offline OMNIFEX  Jamaica
OMNIFEX's Avatar
Dude, your question is kinda broad.
Here are some reasons why PA Tops are generally large.
1. Horn-Loading. The Horn's Mouth will be the deciding factor, on how loud it will play, at the given frequencies.
2. Weight. When your box is too light, it will start dancing on top
of the sub, when you are driving the bass.
3. Matching. Some people want all there boxes to match according to size.
4. Stand Alone. Many of those Dual 12/15 cabs, can play lower, and, are used to play lower notes when you don't need to carry
subs.
You mentioned mid bass. Midbass has a different meaning to each builder. Midbass for me is all the way down to 70Hz.
Some would say 150 Hz. So, each box is built to whatever the sound dude considers midbass.
<--------- ROCK ON !
OMNIFEX
Old 22nd October 2004, 11:04 AM   #3
mike.e is offline mike.e  New Zealand
mike.e's Avatar
Send a message via ICQ to mike.e Send a message via MSN to mike.e
All those things +
Large drivers
Large drivers requiring large boxes
Large efficient drivers requiring even larger boxes for some bass extension
a 1cubic ft box with 90db/1watt drivers arent going to do the job
Hoffmans iron law!
Small,low F3,efficient, - chose 2
Old 23rd October 2004, 01:16 AM   #4
paulspencer's Avatar
Bigger than needed .... for what???
The necessary size relates to the relationship between:
* output
* bass extension
* efficiency
* power handling
So it really depends on what output level you are trying to achieve as well. They may in fact need to be big to achieve the output required, depending on the power handling and efficiency for the given bandwidth.
Is there a specific target requirement here? Application? Output? Home use? PA?
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 23rd October 2004, 04:23 PM   #5
Default clarification
Well here is is.
IF you have a dedicated top to go with a dedicated sub is there any reason to make the top able to play frequencys that it will not have to handle.
fex this 12inch woofer wich really require a 130l vented box to play some bass,but a 40l sealed box would do in theory because it wont play anything below 110hz anyway.
Sure if I want a big,heavy "big speakers need big enclosure" type thing I woul not settle with anything less than a 130l box.
But I dont.
thanks for reading.
Old 23rd October 2004, 05:28 PM   #6
See how it models and that should tell you. I can't see any need for a large vented box in this case, just as long as the sealed box isn't too small, in which case you get a peak in the response before rolloff.
Old 24th October 2004, 07:41 AM   #7
OMNIFEX's Avatar
Default Re: clarification
Originally posted by holger honda
Well here is is.
Here's your answer dude...............
subs
OMNIFEX
Old 24th October 2004, 11:22 AM   #8
pinkmouse's Avatar
Something to bear in mind sizewise, is that a main consideration for pro boxes is how neatly they pack in the truck, and stack/fly by the side of the stage. This often leads to bigger boxes than you would initially expect...
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
DPA Bigger Bit Dac Gretsch6136 Swap Meet 1 1st April 2008 03:11 PM
Bigger is Better...as a 2-way? Spasticteapot Multi-Way 0 24th November 2006 08:06 PM
Big, bigger, .. Nielsio Planars & Exotics 7 20th December 2003 11:55 AM
Characters getting bigger and bigger Elso Kwak Everything Else 11 31st May 2003 10:43 PM
Page generated in 0.10989 seconds (76.70% PHP - 23.30% MySQL) with 10 queries
