Old 21st October 2004, 02:03 PM   #1
ALFIrE is offline ALFIrE  Belgium
Default crossover mounting inside box?
Hi!
I'm in the middle of building my first set of speakers.
Due to the WAF, they are relatively small.
Now, I'll have to mount the crossover inside the box (WAF!), but since it is a small box (.18cu ft - 5 liter), the filter components will only be about 4,5" - 12 cm away from the backside of the mid/woofer.
Will this give me any problems?
The filter will be built as the attached pic. Is this OK?
Old 21st October 2004, 03:23 PM   #2
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
For small boxes you don't have a great deal of options and behind the woofer, at the bottom of the cabinet or at the side is OK.
What you want to do is have the inductors at right angles to each other (one flat, one standing up) and at least 75mm apart. A good idea for small boxes is to put the tweeter xo at the top of the box near the tweeter and the woofer xo at the bottom of the box near the woofer. Helps avoid magnetic coupling between the inductors.
Hope this helps.
Cheers
Old 24th October 2004, 05:22 PM   #3
thanks for the reply!
I'll try to mount one coil at the top of the cabinet, and the other one at the back. This way, one will be standing up and it will require less space on the back.
It has been fun building my speakers so far. I hope the crossover won't ruin that!
Old 24th October 2004, 06:06 PM   #4
cjd is offline cjd  United States
You may have issues with the inductor values changing as well, if they interact with any of the iron or magnet in the drivers. It may be fine, just something to be aware of if it doesn't sound the same with stuff mounted in the box.
Perhaps you could make a set of stands that go with the speaks and mount the XO in the stand base or something.
C
Designed my first crossover, tell me what you think, graphs inside pjpoes Multi-Way 7 8th March 2007 11:09 AM
Crossover inside or outside? Audist Multi-Way 4 25th December 2006 07:39 PM
reason for crossover mounting location jaygeorge1979 Multi-Way 3 6th February 2006 01:02 PM
Mounting crossover to box? Best way? NickZ Multi-Way 2 2nd December 2005 04:39 PM
Best technique to install crossover inside cabinet? BobPM Multi-Way 17 5th September 2005 05:21 PM
Page generated in 0.08411 seconds (71.75% PHP - 28.25% MySQL) with 11 queries
