Old 21st October 2004, 02:48 AM   #1
Optical is offline Optical  New Zealand
Default Best enclosure for a phenix gold xmax 15"
At the moment i have this woofer sitting in the fane rear loaded folded bass horn and it is doing some serious damage, but i wanted some expert opinions on whether this woofer would be better suited in another box..
Presently it is used in a dj setup where drum n bass is the flavour, it certainly takes care of the low end, but after extensive listening you get the feeling that there is something missing from the upper end of the bass.. although i havent made up my mind on this yet..
the sub is controlled by the LC audio active filter (tunable 4th order LP)
aside from this, if this is the best enclosure for this sub then im thinking along the lines of building a reflex cabinet for another 15" subwoofer i have lying around which is tuned higher to complement the present sub..
phenix gold xmax 15 subwoofer specs:
Qts: 0.32
Vas: 306.7L
Fs: 21.81 Hz
Re: 4.06 R
Le: 4.26
Xmax: 0.026m !!
Z: 4.00 R
Qms: 0.34
Qes: 0.34
SPL: 91.00dB
Pe: 500W
Bl: 18.05
dia: 0.381m
Sd: 0.859m^2
Old 22nd October 2004, 01:24 AM   #2
do i smell or something?
Old 22nd October 2004, 03:39 AM   #3
Luke (Uof Iowa)'s Avatar
So you want a BR design for the PG? Try using a program like WinISD.
http://www.linearteam.dk/
Gold plated female quick connect spade terminals (.110", .187") dholcombe Parts 1 29th January 2008 11:16 PM
What is the most durable 8" high xmax woofer? sardonx Multi-Way 14 24th July 2005 07:18 PM
Longest one way xmax on a 12" Ilianh Subwoofers 4 18th September 2003 12:00 AM
12" driver with big Xmax,low Fs, & high efficiency? WolfmanX Multi-Way 18 26th November 2002 11:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
