Hi all,
I'm still fiddling with my surround speaker project, and I've been here to calculate the basic crossover components for a 4ohm tweeter, and an 8ohm woofer: http://www.lalena.com/audio/calculator/xover/ But how do I know what impedance that will be showing to my amp? I'd like to keep it at approx 6 to 8 ohms, but given my very basic knowledge of resistances in parallel, will this set-up be showing less than 4ohms? I don't know the differences between 1st order, 2nd order etc, so as you can see, I've a lot to learn. Any help appreciated Gary. |
#2 |
For frequencies passed by the filter to the tweeter it will see 4 ohms, for frequencies passed to the woofer it will see 8 ohms. You may want to look at sensitivity more than impedance. Chances are you will need to pad the tweeter anyway to compensate for increased sensitivity over the woofer.
#3 |
Hi tim,
Thanks for your reply. Ah, Ok, So the amp will see different impedances depending on what it is sending to the speakers? How do I go about padding the tweeter to make it match the woofer? If the sensitiveity of the tweeter is say 3db higher, what is needed to compensate? I feel I'm asking very very simple questions, but can't find the answers by searching, so I kinda feel like a dope. Gary. |
#4 |
The best way would probably be to use a selectable L-pad and once the tweeter is where you want it replace the L-pad with the same value resistor(s).
Some people use L-pads as a permanent installation though. |
#5 |
Thanks Tim,
Good idea! I can use the l-pad for other projects too which is handy. What's the best way of measuring the sensitivity of the tweeter after adding the l-pad? Will the resistance add to the overall impedance of the tweeter? Gary |
#6 |
What system will you use for measuring your speaker? I suppose you could do it by ear but you'd do best by getting some measurement software. There are many choices.
The padding resistors that replace the selectable L-pad are often referred to as "L-pads" because they shape an L in a schematic. In other words, you have a series resistor and a parallel resistor. This not only attenuates the tweeter but presents a steady load to the amp. This may clarify it some. http://ccs.exl.info/cust_cr.html |
#7 |
Thanks again Tim,
Actualy, that was to be my next question! I've seen some software which needs you to make up a box - Speaker Workshop, but will a simple microphone, test tone and recording software do a reasonable job? The SW stuff looks very useful for ascertaining the T&S data which I'd like to try sometime, as I couldn't get any info on some Acoustic Energy speakers I have (I was going to use the drivers and crossover in a new box, but the new box I made is too big, so I need to see what to change, other than the internal volume). What would you reccommend for a very green newbie like myself for basic testing? TIA Gary. |
#8 | |
#9 |
Yep, I second the David Weems book for getting started. In particular, "The Great Sound Stereo Speaker Manual". Just take his quarter wave theory with a "grain of salt" if you know what I mean.
#10 |
hi, does anyone know of any good books i could get to assist with my high and low pass filter settings ? i have 2 x 12" Lightning Audio Subs (300Watt RMS)with a Starsound 1500Watt Amp -
Ultra stable PWM (pulse width modualted) MOSFET power supply 2Ω stable operation with output power increase Variable High pass filter (40Hz - 1KHz) & Low pass filter (40Hz - 250Hz) Enhanced variable crossover for Super Bass OdB/ +6dB/ +12dB @50Hz RCA line Input and line Out jack Gold plated Power, Speaker terminal Soft start delay turn-on circuit Automatic remote ON/OFF switching Bridgeable & Tri-Model operation Full chromed finish design Protection circuit against Thermal, Overload, Short circuit and DC Offset i've only got the 2 subs connected to the amp ( not bridged ) and nothing else. the rest ( 6x9's and sub-standard 80Watt speakers to serve as mids ) all run off my head unit ( JVC shuttle controller - 40 x 4 ). the amp sometimes clip - probably 'cos of my gains being set too high ???? when this happens, i turn down the gains but still get intermittent clipping at high volume and bass on the head unit... please please please - i will greatly appreciate any advice as i am only a novice and learning - please please please.....? |
| Serious newbie has a crossover question | Binkstir | Multi-Way | 9 | 26th March 2009 09:46 PM |
| Ways to Prototype a Crossover? (newbie question) | diesel_88 | Multi-Way | 12 | 27th October 2007 07:22 PM |
| Newbie crossover question | ejc | Parts | 1 | 28th December 2006 01:58 PM |
| Newbie crossover impedance question | Xylenz | Multi-Way | 2 | 22nd November 2002 07:58 AM |
| Crossover question, real newbie | Christian | Solid State | 3 | 12th July 2002 03:23 AM |
| Page generated in 0.11423 seconds (84.03% PHP - 15.97% MySQL) with 10 queries |
