I was having a discussion with a friend of mine about what type of enclosure would be the loudest for a single given frequency, i.e. 50hz.
I settled on some type of double tuned bandpass, he went with a simple ported alignment. So, which enclosure type can be crowned loudest of them all? I know there are much more knowledgeable pros on this forum that could answer this without even breaking a mental sweat. TIA, MEXXX |
#2 |
This is just my opinion and experience:
A well tuned Bass-Reflex (ported) can be more loud than a bandpass enclousure. I have a bandpass subwoofer and a BR one. Both have the same driver and the BR is louder. The bandpass only gets lower frequencies than the BR. Remember, this is my experience with my enclousures. Regards |
#3 |
I agree that a well tuned BR enclosure can be louder than a bandpass when both are designed to play a fairly broad frequency range, BUT....... When I model the two enclosures to play a single frequency as loud as they can, a double-tuned series bandpass seems to come out on top.
#4 |
Yes, but... what about the other frequencies?
Are you going to play ONLY 50Hz ??
#5 |
Surely a horn's more efficient ('LOUDER') than either
#6 | |
SPL competitions make about as much sense as NASCAR racing .
#7 |
Bandpass would probably be his best bet (They are big on one note wonders in Finland and they are starting to use a lot of bandpass stuff), Bass reflex is much simpler to do though and a lot more tollerant of errors. Horns would be ideal but its usually a space issue, even a folded horn to hit 50Hz is pretty damn big, try squeezing one in a car! Although you may well just get one in a van.
#8 |
AFAIK, a compression driven tapered pipe, i.e. a type 1 (sealed back) bandpass tuned with a tapered (to reduce the length and further load the driver) vent to 50Hz. The driver will have to be custom made to get the near 50% efficiency it's capable of and the power handling required to reach the SPL required to 'blow the doors off'
If you must use a readily available point source driver, then find the lowest Fs, Qes, and highest Pe, Xmech driver available for its frame size. To gain acoustic efficiency, use a driver size that yields the highest compression ratio that doesn't 'lay down' from thermal power compression, rip something, or burn up in the time frame of the 'run'. IOW it's only good for as many 'runs' as required by the rules, so at a glance an 18" HE driver with a high Mms and super strong motor to keep Qes low is the 'Hot Ticket'. Remember, the highest efficiency racing motor for a given set of rules/conditions blows as it crosses the finish line so design it for easy driver replacement between 'runs', yet still seals completely as any leaks will 'kill' most of its efficiency. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#9 |
If it doesn't matter when the thingie has a bipolar characteristic then a quarter-wave pipe on the front AND back might do the trick.
I once wanted to try this out as a neigbour-annoying device. Regards Charles |
#10 |
GM, did you just describe the Adire Maelstrom?
I sure hope not, because I already own one and curiosity might kill that cat by the weeks end Also, how would one go about modeling a compression driven tapered pipe? Is there a worksheet for such a design? |
| Changing enclosure type? | Johnnz | Multi-Way | 1 | 8th August 2008 10:53 PM |
| What type of enclosure?? | e-side | Multi-Way | 5 | 25th December 2005 06:17 PM |
| Page generated in 0.09081 seconds (85.30% PHP - 14.70% MySQL) with 10 queries |
