Old 19th October 2004, 02:40 AM   #1
bser is offline bser  United States
Default help me with my first diy
Okay so I've done some major research in the past 2 weeks since first discovering this site, and I've learned alot. But there is one way to really learn how to do stuff and that is to just do it. So I'm gonna start cheap with some drivers that I won't cry over when they break but can still yield some satisfactory results. What I'd like to do is start of my diying with a simple 2way stereo setup consisting of a driver that goes pretty low, so as not to need a sub, and a tweeter that can cross the mid at 3Khz or so. My budget for this "starter set" of speakers will be very limited so I have cash left for actually building my real HT setup once I get felling better about my speaker building skills. I'm looking to spend about $100 total, so the way I figure I have maybe $60 to spend on speakers. Can someone recomend a quality woofer and tweater that fits the bill? A speaker combo that has been used often is also good so I will have acess to some crossover diagrams as I have never done them before either. Thanks to all who take time to help
Old 19th October 2004, 02:55 AM   #2
I forgot to mention that I would like to use these drivers in a ported setup, the amp I have is an old kenwood 100x2 stereo amp, but these speaker by no means have to handle that.
One setup I was looking at was:
woofer: 2x dayton reference
http://www.partsexpress.com/pe/pshow...=295-362&DID=7
tweeter: 2x HI VI TN28
http://www.partsexpress.com/pe/showd...number=297-409
will these work well together?
Old 19th October 2004, 03:01 AM   #3
Bill Fitzpatrick's Avatar
$30 per channel on drivers is really low, but not impossible. If you build something, it is no more trouble to build it right so you needn't think in terms of throwaway test units - build a pair of keepers.
If you would consider increasing the budget a bit, I offer the following for your consideration.
http://www.adireaudio.com/TextPages/...eFrameText.htm
Of course there are loads of other possibilities.
Old 19th October 2004, 04:14 PM   #4
RJ is offline RJ  United States
That RS-150S 6" speaker you chose will probably need a 3rd or 4th order crossover to get past that cone breakup starting at 5K...
The SPL matches the tweeter .
The box is small - .4 cu. ft. or 11.5 Liters..
If you could wait a while the guys at Madisound or Parts Express or busily building speakers with that woofer...
PE Express; http://www.pesupport.com/cgi-bin/config.pl
Madisound;http://www.madisound.com/cgi-bin/discuss.cgi
Project Showcase
;http://www.partsexpress.com/projects...homeaudio.html
Speaker Builder;
http://speakerbuilder.net/web_files/default.htm
At least this is a start....rj
Old 19th October 2004, 08:42 PM   #5
RJ are you saying to email those guys with a question and they may design a crossover suitable for the woofer? Would I still need perhaps a 4th order crossover if I plan on crossing the woofer at 3Khz?
Bill that adire link looks interesting, but what can be said about the sq? I'm a little worried about the quality of drivers used in the project, sure the response is flat, but as I've heard this isn't all it take for a good sounding speaker.
Are there any other projects like that with perhaps slightly better drivers that can easily be reproduced? And lastly is there a good program you all use to help calculate crossovers for certain drivers, or what does it take to know what kind of a crossover will work well with a certain driver?
Old 19th October 2004, 09:21 PM   #6
5th element's Avatar
I would not recommend using that woofer unless you have the skills. Its not a nice driver to work with.
The tweeter and woofer might be the same sensativity but you still need to use baffle step which will cut the woofers sensativity by up to 6dB.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 19th October 2004, 09:24 PM   #7
usekgb is offline usekgb  United States
usekgb's Avatar
If you're not afraid of some woodworking, you might want to try this one:
Dayton TL
Zach
Ahhhhhhhhh...............That's what that button does.
Old 19th October 2004, 09:28 PM   #8
I realise that my first post wasnt very helpful.
No what he means is that in time someone will come up with a design that you could use.
Yes, crossovers are not instant and roll off at various rates. If the resonance is at 6khz using a 1st order will have the 6k peak down by 6dB. This isnt very much. A fourth order network has it down 24dB which is much better. Steep slopes with notch filters are required to tame resonance peaks associated with metal cones.
Yes there are many kits available that use better quality drivers which can be easily made.
Speaker workshop by adua is the only free simulating program out there so maybe you should have a go with that. You will need to use SPL trace to copy the response of the drivers from picture files.
What it takes is knowledge learnt over time.
Old 19th October 2004, 10:28 PM   #9
The Dayton RS Drivers just came out late last month. Theres not enough speakers built yet to come up with a solid design. There are advanced DIY'ers that are building speakers with these drivers right now.
I'm following xgecko on Parts Express Tech Talk and his project.
I want to know how the BG Planar/Ribbon tweeter matchs up with these aluminum drivers.
My idea was to use 2 8" RS drivers and 1 BG Planar/Ribbon in a tower speaker. Like the Dayton 8's--- http://www.wadsnet.com/~dtenney/dayton_8MTM.htm
There's a bunch of free speaker design software here;
http://www.pvconsultants.com/audio/frdarticles.htm
You'll need Microsoft Excel Spreadsheet program to use most of them..
Hope This Helps ---- rj
p.s. If you need more help keep asking....
Old 19th October 2004, 11:48 PM   #10
Timn8ter's Avatar
I was going to say the same thing. The guys at Adire still listen to these in their warehouse. That is, when Dan's not going crazy with the Hurricane.
Page generated in 0.11718 seconds (90.79% PHP - 9.21% MySQL) with 9 queries
