Some time ago I did build some Studio monitors for some friend of mine and lately he complained that on certain lowmid frequencies (between 400 and 800hz, especially some guitarsounds) he would hear some kind of distortion when mixing on high volume (more then 80 watts into the mid/high section)
It's more like a loud "click" or "tick". I took home those speakers and came to the conclusion that it was the highpass of the MID speaker. It's a regular highpass with a crossover at aprox. 400hz. L=1,4 mH and C=68uF, the speaker is 4ohm. It tried several amps and other speakers to really make sure that it was the crossover. Then I tried a 6db/oct highpass (only the capacitor), the whole problem was suddenly gone! After that I tried other coil values, a higher value would only make the problem occur at higher volumes. Adding a resistor in series with the coil would do the same thing, but the problem is still there. I also tried an LCR on the mid speaker to smooth out the impedance at the resonance frequencie, but without succes. Are there other people who did have this problem, I think it's just the limitation of passive crossovers, right? Maybe someone can tell me more about it. |
| Active highpass filter - ground | skogs | Analog Line Level | 3 | 19th June 2007 06:25 PM |
| Measuring tweeter FR without a highpass filter | owdi | Multi-Way | 3 | 14th March 2007 05:40 AM |
| Tweeter highpass | Khron | Multi-Way | 2 | 27th May 2006 01:41 AM |
| Highpass filter using sound card??? | vsboxerboy | Digital Source | 0 | 18th July 2005 08:59 AM |
| highpass amp strategy for active system? | PWatts | Pass Labs | 1 | 3rd November 2004 06:43 PM |
| Page generated in 0.07110 seconds (74.63% PHP - 25.37% MySQL) with 10 queries |
