Merging Pro Audio and Home Audio
Hi all.
I would like to build some speakers, but have a few questions first. I've only built one or two so far... nothing very special. I really need to get a good book on speaker design. I have one, but it's about 60 years old now... It's called "Hi-Fi Loud Speakers and Enclosures." Fun to read, but a 60 sq. in. port for a 12" speaker? What?!?!
Anyways, I have a few questions regarding speaker design and speaker types. I'm blaming my dad for this... he has a pair of Wharfedales set up in his office that we found at a thrift store (12" woofers, 4" mids, 1" tweets... real "furniture" speakers from the 60's...) along with a pair of old 12" Electrovoice Wolverine speakers and a pair of Utah horn tweeters from his college days. I have to admit, the setup sounds really, really good. The Electrovoice's really add a lot of "presence." I am wondering what you all think about using Electrovoice speakers (or similar PA-style speakers) as midranges in a pair of floor-standing units. I'm thinking about getting a pair of old PA speakers off of eBay (have seen some good deals on old Electrovoice hardware) and pairing those with dome tweeters and 10" woofers. I'm looking for something around $150 for the pair, not including wood. As far as reproductive quality goes... I listen to everything from jazz to industrial/gothic music to death metal. A sealed design would be best. Would particle board work for this project or would the box just sing? I already have a bunch of 3/4" particle. I'll be running them using a Kenwood HT system with 100 WPC.
What are your thoughts on using pro audio speakers in this manner?
Owen
Hey Dude! :cool:
Electrovoice makes great pro audio equipment. Pro Audio
is my cup of tea. I'm kinda :confused: on some Home Audio
concepts.
The Electrovoice Wolverine is a Fullrange Speaker. So,
you would need to find Pro Audio Fullrange Speakers
that offer similar characteristics.
Unfortunately, not many offer the same response, like
your wolverines.
I would stick with the older EV Speakers, for the new
ones, offer a more limited bandwidth. So, look into
the EVM Series. They offer 10, 12, & 15 inch Loudspeakers
that should offer what you need.
JBL offers some as well. However, I'm not familiar with
their model numbers, and, they offer too much numbers
to second guess.
Basically, search for the older drivers, they will give you
the sound you are looking for.
Personally, I'm using EVM 15B's, and, would recomend
the EVM 10M for your requirements.
Rock On! :eguitar:
My sister picked up some old Wharfedale speakers probably very similar to what you mentioned - 2 ways with a 12" accordian surround midbass and a tweeter (not sure what type it is). Proabably about 30 years old. Very nice sounding.
I'd say you could pick up some speakers like that cheap and put them in some better boxes. Better here could mean more inert as well as more attractive. You could also experiment with a larger box as many of them had quite small boxes considering the size of the drivers.
These speakers tend to be high efficiency, so if you want these type of drivers in your system, the drivers should match in sensitivity. If you put drivers like these in the midrange and then add regular hifi woofers and dome tweeters, the midrange will shout! It will probably be +5db more efficient! Bad idea!
A lot of people like the sound of high efficiency drivers, especially those who like to use low power tube and valve amps. These older speakers made up for lower amplifier power by using 12" woofers for the bass and midrange. Now a 6.5" driver will do the same bandwidth but needs more power and excursion.
Vintage Sound
I'm with you guys. I prefer the big tone and smooth sound of some of the older designs like the Altec A7, Klipsch, EV.
I figure the less a woofer has to move the better. If you want to look at current drivers, you could probably pair up an Eminence Beta 10 or 12 wide range driver with a 15" woofer for a big box full range. Some of the BMS, B&C, and Ciare co-axial designs look to be an improvement.
Adire has a pro sound box on their site that uses an 18" and a Beta in a ~7 cu. ft. enclosure, IIRC.
Otherwise, any of the vintage Altec Duplex, Bi-Flex, EV Wolverines, University and so on, could be used. Sizing the box may be made easier by looking at the older design dimensions and duplicating.
Tim
Paul, I would urge caution with this. I recall reading someplace that the old sealed woofers (of the era we're talking about) relied more on the air-spring of the small box as a restoring force than the woofers of today tend to. Without knowing (would need to measure, I'm sure) the T/S parameters, I think you'd risk overexcursion.
Also, particle board was mentioned. I'm surprised someone else didn't already say how much they hate particle board- so I'll say it. Particle board is tough to work with! It's also not very strong, and it's easily ruined by moisture. If you've got it and you're on a tight budget, I won't tell you you can't use it. Just consider doubling the thickness and/or using internal bracing. If you build these out of particle board, don't plan on moving them- the edges and corners will be delicate.
Sorry if my response was a little negative, I haven't had my coffee yet. :dead:
good luck, and best wishes
Smaller is better, for now.
Thanks for the suggestions, guys. I'll keep you posted on the progress of the project (which will be slow... the best plans are laid to waste by college...)
Agreed... can't go wrong with the classics. I have seen some pretty good deals for Wolverines on eBay lately, ex.:
8" EV Wolverines
I kinda figured that much. :xeye: I want to keep these fairly small. And yes, I really like the idea of high-efficiency speakers. It just seems pretty hard to get decent bass out of these low-excursion PA speakers without some insane horn loading. What bass there is, though, is incredibly tight, and I love that sound. The book I mentioned actually gives quite a few plans for old University and Electro-Voice drivers, but they'are all huge corner-horn or acoustic labyrinth designs. And lets just put it this way... I'm going to have to let my parents use these speakers until I move out of their house because I can't fit anything bigger than bookshelf speakers into my room. :( I guess the best way to go with these is to pair them with a seperate subwoofer?
I know, I know... :( I don't like the stuff either, but I've got a ton of it lying around and I figured it might work. I will add internal bracing to the speakers. Plus I am trying to stay around $75 per speaker.
I'm toying with the idea of putting protective wood pieces on the corners of the speakers. It'll look a little funky, but would save the box. Wanting good sound and being cheap don't go well together...
Anyhow, thanks again and keep the suggestions coming.
Owen
Good point, I'm glad you mentioned it. I should have in fact thought of this. It's probably not a good idea to change the volume.
In a HT setup with the speakers set to small these speakers could perform very well. You could get very high output due to their efficiency and increased output due to 80 Hz highpass filters.
If you have particleboard, you can still use it. I wouldn't buy it, but it can be made to work. Suppose you have 18mm particleboard. You could put 12mm MDF on the outside and some bracing inside and get a very solid box. If it is a well finished sealed box, then I don't imagine moisture should be a problem.
Adire has a high efficiency kit which might interest you. It's a bit more compact perhaps and you can make 5 identical speakers.
Still, if you buy old speakers like these you can get bargains. My sister was thinking of replacing the ones she has with some new speakers which would probably be more expensive, smaller but vastly inferior. Since most people don't trust their ears as much as their eyes, perception can work very well in your favour.
My sister was very surprised when I told her how good those speakers were, and that she would have to spend AU $1000 for new speakers to match them.
Particle board will work just fine. Its been used for decades by everyone, and the speakers are still around. Its no more difficult to work with than MDF, and its better than MDF as far as moisture is concerned (get some MDF wet, and watch it swell). For a tweeter, a good one to use, and also inexpensive, is the Selenium D150. Horn loaded, with a phenolic diaphragm (much like the original EV horn tweeter). Kick it in around 5k. You will need an 'L' pad, because its more efficient than the Wolverine. Unfortunately, if you want good bass from the Wolverine, it will need a big box. That was the nature of the speakers, then. Go to Terrys EV site for enclosure information on those drivers.
http://www.geocities.com/tadgesualdo/12trxbwebsite.html
Go here for info on the D150's
https://secure11.websitecomplete.com/sharrongrp/shop/showProd.asp?prod=2385
Something completely different...
Well, I've decided to go with something completely different. I want to stick to floorstanding/tower style sealed enclosures. There are some nice looking rubber-surround poly woofers in the MCM Electronics catalog (here), and I was thinking about a sealed design that uses two of these drivers, matched with a 5" midrange (here) and a silk dome tweeter (here). My thinking is the bass would be tigher with the sealed/rubber surround combo (correct me if I'm wrong.) The speakers will still probably have to be rather large. Is there any way to isolate the midbass without having to build a little box around it inside the main cabinet? I've seen cardboard tubes used for this, but don't know where you'd find them.
Back to my original question though... I love razor-sharp transient response in bass. Would substituting the woofers I mentioned above with a "musical instrument" speaker like say, something like this put out punchy bass without having to depart from the small sealed enclosure design?
Also, would I calculate the volume of the enclosure just by taking the VAS x 2?
Thoughts?
Thanks in advance...
Lost,
I think you were onto a good idea but now you seem to be getting ... well, lost! (Sorry, couldn't resist)
Those drivers you mentioned. None of them seem to have response plots and they look a bit ugly to me compared to what diyers mostly use. This is not to turn you away from MCM as they seem to have good low cost bang for buck drivers. Stay away from instrument speakers for home audio! High efficiency is one thing, but these are in a class of their own, intended for their typical use often due to having a certain tone based on harmonic distortion. Have you ever heard music through those things? It sounds worse than the cheapest clock radio!
Another question: how are you going to design the crossover?
Going back to your original idea how about this ...
Get some cheap old speakers and give them a cosmetic upgrade and add a decent sub to fill in the low end. Avoid ebay unless you know the speakers and have good pics. Instead do some hunting around secondhand shops, as you get to hear them that way. Act semi interested in them, as if they are cheap and nasty boom boxes and see if you can bargain them down a little.
You might strip off some of the old vinyl and give them a paint job or put some new veneer on them. You might also use more acoustically transparent grille cloth as many of them use very heavy grilles which mess with the sound. If they sound too bright you might experiment with an Lpad (very easy to add). You may even choose to make the box a little more solid.
Well, actually I have been doing that... for the past year! I haven't been able to find anything decent yet. Mostly all I see is cheap 80's speakers. As for older speakers, the drivers are usually damaged - rotted surrounds or dented-in dust caps (even the ones my dad and I found had dented in dust caps). So you might say it's been a little frustrating. And size is an issue... they have to fit in what little space I have, which means tall and narrow. I don't think replacing damaged drivers would be fun, though I might be willing to try it if I had more knowledge.
As for what I was saying before... the crossover was the next thing I was going to tackle. And no... I haven't heard music through musical instrument speakers, hence my question... :confused: The (flawed) line of thinking goes if you use the speakers originally used to make the sound, it'll sound like the band is right in the room. If it were only that easy!
Anyways, I usually go to the thrift stores around here on the weekends and always look for speakers. I'll let ya'll know if I find anything.
Getting lost you mean? ... so you must be quite an expert by now! ;)
*tongue in cheek mode disabled* ....
Sounds like the hunt isn't working out for you. Also sounds like even if it did, the shape doesn't work either. They also tend to be a little low and look funny up on a stand to get the tweeter at a better height 0.9 m - ear level.
That would be fine if the musicians were there plugging in their guitar! They get their guitar amps to sound just as they want them, to make their guitars sound right. They want it coloured. But once that has been captured, you don't want to keep adding to it with your speakers!
Sounds to me like what you want is something a bit more modern. Some slim towers perhaps. There are a lot of good kits and designs out there. If you want to design your own then you have quite some work to do!
You know, there's a pawn shop around here that has a lot of modern tower speakers. I don't remember what they wanted for them when I was there last, but I'm pretty sure they were overpriced. Think I'll mosey on down there tomorrow or Saturday.
Thanks for the info, Paul. I'm trying to stay within a budget of $75 per speaker, though. Most of the larger kits I've seen cost a good bit more than that. I'll keep you all posted regarding my pawn shop finds.
I'm in the process of building some mini monitors right now, actually. I'm using 2 of these 5 1/4" drivers and these tweeters. I have one built but I've got a resonance issue I'm trying to work through. Probably just need a crossover on the woofer, or else built the box too large (I just kind of threw it together last weekend...) May try a bag of sand in the box once the ground dries up. We finally got more rain out here in the desert. Now we're up to 7 inches this year!
