Adire Speaker Idea .. comments?
Old 15th October 2004, 05:50 AM   #31
joe carrow is offline joe carrow  United States
Send a message via AIM to joe carrow
Very nice, Paul!
How I wish I could afford to build one of those
Old 15th October 2004, 06:26 AM   #32
paulspencer is offline paulspencer  Australia
paulspencer's Avatar
Another thing to consider is the power required to each driver, which is affected by the way the bandwidths are divided.
Power bandwidth table
With crossover points of 250 Hz and 2.5k you need approx:
25% of total power to the tweeter
35% mid
40% bass
So to get the equivalent of a 200w amp you need:
50w tweeter
70w mid
80w bass
Considering the losses in a passive system you may in fact only need not much more than half that, or if you had that much power, you could just have a bit more headroom.
In practise the bass needs more power as bass tends to be more dynamic, so this might be more suitable:
20w tweeter (a diy class A amp would work just fine)
40w mid
150w bass
This is assuming the efficiency of the drivers is matched. Now this is where things get more complicated, as if you don't get this right, you can end up changing the crossover points!
I suspect a plate amp would control a woofer like the Koda better than a Rotel receiver, which is also probably lacking in power if you want the Koda to extend below 80 Hz.
I recommend having a look at this ESP article on biamping and browing through other related articles on the site. Very good info!
You may also find active analogue crossovers of interest. You dont' have the same flexibility and power but it is cheaper and many consider it a more transparent option.
Old 15th October 2004, 02:41 PM   #33
kfr01 is offline kfr01  United States
kfr01's Avatar
Originally posted by paulspencer
[B]
Now a few different ideas.
TMW + sub
Vifa XT tweeter
CSS - 4.5" widerange driver with XBL2
Adire Koda - (80 - 300 Hz)
Thanks for the great replies! I do like the idea of using as much XBL2 as possible. That 4.5" looks like it would fit the bill. Maybe I'm a sucker, but after reading the material on adire's site they sold me on that technology. I also have to say I like the idea of adding the Koda 8 back into the mix. It seems like it might add some otherwise lacking 'punch' and midbass finesse.
Would you elaborate on this step? Assuming I use the Behringer, what steps would I need to take to correct for this?
Also, on the link you sent me the man showed and briefly mentioned an attenuator he made for the Behringer's outs. He mentioned that the pro-sound outs were too strong. Do you know if this step is necessary?
Thanks again!
Old 15th October 2004, 03:08 PM   #34
Luke (Uof Iowa) is offline Luke (Uof Iowa)  United States
Luke (Uof Iowa)'s Avatar
FYI today is the last day to preorder the Extremis at a discount.
Old 15th October 2004, 03:37 PM   #35
I think it makes sense to have XBL as much as possible. And I would certainly not leave it out of the bass! I think this is where Adire have a very significant "point of difference." Their drivers using XBL for the midrange perform well, but there are already drivers that do this successfully. It appears to be what they have done with subs that is most impressive. If you are going to spend the money on Ultradrive and the amps to go active, then you might as well go with XBL drivers for the bass and sub bass as well.
There are other drivers which show their BL curve - see the Dayton Titanic and DVC on the Parts Express website. It appears to perform quite well although the DVC doesn't look so good if I recall. The Shiva is probably very similar.
If you budget doesn't allow for the Tumult, then a pair of Koda drivers should perform quite well for a while. They would not be that far off the SPL of the Shiva, but they would have lower distortion. If you use them in the way I suggested then the real sense of power and punch would come from the Tumult. I'd call 40 - 60 Hz or so the midbass punch.
In fact, if you are using the Tumult then I would suggest using it as high as you can! (actually my guess is that 60 - 80 Hz would work well) There shear output, authority, performance and low distortion of this driver is amazing. (I have heard it).
This is where I suggest you have a look at the article on bi-amping! Yes it is a long read, but it will explain this. Basically you have to deal with different speaker sensitivities with the gain of the amplifiers. You would think that you could just adjust the gain on the active filters, right? ... but if you do this, the crossover point will also be shifted. It's shown in the article and here is a pic to explain:
Suppose you have a bass driver with 2db less sensitivity. You need 2db more gain to that amplifier to compensate for this. Every amp has a gain ... eg. 28db.
If there is another way to deal with this, I'm not aware of it. Perhaps some others can shed some more light on the subject, or suggest some ways of dealing with this.
Thanks again!
I haven't used Ultradrive and Luc knows more about it than I do.
Adire Speaker Idea .. comments?Hide this!Advertise here!
Wacky TL idea, comments? sifka4 Subwoofers 5 25th November 2008 01:43 AM
New speaker design... comments please ! Andy G Multi-Way 8 18th July 2006 01:12 AM
portable speaker idea : comments? quiet Multi-Way 1 16th July 2005 02:52 AM
Comments on speaker config, please! MASS Multi-Way 2 14th January 2004 10:24 PM
FS: Adire Audio speaker system with sub Wright Swap Meet 7 10th August 2003 05:33 AM
