I have a pair of Tannoy 10" Monitor Golds in their standard IIILZ cabs.
The drivers are wonderful, but are severely compromised by the small IB cabinets. In particular, the bass extension is poor, and the midrange 'boxy'. Having once owned a pair of big IMFs, I'm a big fan of transmission lines. Would the Tannoys suit TLs? Anyone tried them? Suggestions please! Cheers, Dave. |
#2 |
Got ~accurate T/S specs?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
Are T-S specs much help for TL design? If you 've got the length of the line right for the Fs of the speaker in the line, how much do changes in Vas or Qt affect the performance?
#4 |
It can be considerable since the length/cross sectional area is critical to getting optimum performance, i.e. max acoustic gain at minimum 'ripple' in the FR with the least amount of stuffing. To use an extreme example, one I did recently required a 48.54Hz 1/4WL pipe to damp down the huge midbass 'hump' of an 83Hz Fs/~2.45 Qts driver. If it had been tuned to 83Hz, the 'hump' would still be there and have a wider BW, with the attendant greater 'ripple' higher up to boot.
GM
#5 |
Thanks guys,
These were madwe long before T&S pubished! There are very sketchy figures available, but not enough to be much use. [URL=http://www.thielesmall.com/include/details.asp?ID=4972&dtype=1] I could, of course, measure them, but haven't done so yet. |
#6 |
I found these: http://www.hilberink.nl/codehans/tannoy38.htm
Assuming they are ~accurate, the low Qts means a very rolled off response beginning around 500Hz unless significant series resistance is added from a high output impedance tube amp and/or external resistor and/or high DCR inductor. For instance, if we double Re then we could get a ~T/S max flat down to 30Hz in ~8.09ft^3/25Hz Fb, with the trade-off being a ~3dB lower effective efficiency. If you feel like gambling with these specs and don't mind the lower efficiency, then how big of a cab can you handle? GM
#7 |
With the low Qt, they are ideal candidates for active equalisation in the form of a Linkwitz transform circuit between the pre-amp and the power-amp.
#8 |
Interesting thought, Ouroboros.
It might be tricky though to accomodate the coaxial tweeters, which have a notoriously odd native response / impedence, which ois compensated for by Tannoy's peculiar crossovers! |
#9 | |
GM
#10 | |
http://users.bigpond.com/tunnelgap/T...alNumbers.html http://www.hilberink.nl/speaker.htm Ultimately though, given their age and, if you're not the original owner the possibility the drivers were re-coned at some time, the only way to be certain is measuring the T&S parameters yourself. |
| FS: speaker cabs for your Tannoys, Altec, or EV coaxes | whiteSE | Swap Meet | 3 | 12th May 2009 04:10 PM |
| Tannoys in OB, almost there.... | inrank | Multi-Way | 3 | 5th December 2006 07:02 PM |
| Tannoys I just picked up. need help with ID and suggestions... | mpmarino | Multi-Way | 22 | 9th June 2006 07:37 PM |
| Page generated in 0.11015 seconds (82.37% PHP - 17.63% MySQL) with 10 queries |
