Old 17th October 2004, 09:42 AM   #11
joensd is offline joensd  Germany
Wouldn't hurt to try. You may need to adjust the values though.
In theory, shouldn't you be able to place the mid\woof higher in the cabinet? Your goal is different here than it would be for a single driver system. If so, you might be able to build a separate enclosure for the 871 inside the TL that matches the specs for John's filter.
The idea for the TL originated here, so that dictated the position for the mid-woofer.
Yeah, I thought about sealing the TB with a plastic cup.
Will have to see how that goes together with the active-XO and the XO-point.
Will probably try one of those nothes:
http://lautsprechershop.de/hifi/ct209.htm
http://lautsprechershop.de/hifi/lancetta.htm
Dave, I hesitate to do any modifications but just might ty it if nothing helps.
Sorry for threadjacking Jim.
thanks everybody
jens
Old 17th October 2004, 10:52 AM   #12
paulspencer's Avatar
Originally posted by Timn8ter
There is a small vented enclosure for the W3-871S also ... Power handling will not be as good as a sealed enclosure.
A vented alignment should have more power handling than a sealed alignement if designed and implemented correctly. Further, in this application, you can design a vented alignment specifically to get more SPL than a conventional vented alignment by designing a bump in the response and then using a simple active filter to get rid of the hump. This results in significantly more power handling and output.
High end system for reasonable cost Dr.EM Multi-Way 6 16th July 2007 01:23 PM
ultimate low cost FR system regal Full Range 35 19th August 2005 03:51 AM
TV as computer monitor help, please edjosh23 Everything Else 26 18th April 2005 11:50 AM
low cost (£70 max), near field monitor/bookshelf speaker. Puggie Multi-Way 7 24th October 2004 09:36 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
