Old 13th October 2004, 07:51 PM   #1
bra is offline bra
Default Jamo 20338 - TS?
Has anyone TS parameters of Jamo speakers 20338. I have two of them from second hand market and want to use them in 3 way loudspeakers, but without parameters it is imposible to make anything right.
I would be greatful for Your help.
regards
bogdan
Old 15th October 2004, 05:54 AM   #2
bra is offline bra
Nobody can help me?
Old 15th October 2004, 01:27 PM   #3
Pedja is offline Pedja  Serbia
If you are interested I can post 20337’s T/S and these seem to be practically the same units. They are very similar to Peerless 850136 (these Jamos are probably made by Peerless) whose parameters are available, though a bit different than what I’ve measured for 20337. Btw, anyone checked T/S of 850136?
Pedja
Old 15th October 2004, 05:31 PM   #4
bra is offline bra
I would be greatful for this data. It will help me very much. Thank You!
Old 16th October 2004, 02:26 AM   #5
Bogdan, here is the data for two drivers. Please note that the measurement was done with practically new units, after a few hours of burning in.
One driver:
Fs = 37.46 Hz
Re = 5.8 Ohm
Le = 2.43 mH
Vas = 35.28 l
Sd = 235 cm^2 (I’ve taken it as specified for Peerless 850136)
Qms = 7.00
Qes = 0.48
Mms = 40.1 g
Bl = 10.62 Tm
SPL (2.83V, 1m) = 89 dB
SPL (1W, 1m) = 87.7 dB
Another one:
Fs = 35.9 Hz
Re = 5.8 Ohm
Le = 2.41 mH
Vas = 30.55 l
Sd = 235 cm^2
Qms = 7.00
Qes = 0.51
Mms = 50.5 g
Bl = 11.32 Tm
SPL (2.83V, 1m) = 87.7 dB
SPL (1W, 1m) = 86.3 dB
Pedja
Old 27th October 2004, 04:31 PM   #6
bra is offline bra
Jamo Concert 7 kele1975 Multi-Way 2 28th April 2010 09:51 PM
Jamo Dynamic 80 c0nfu33io Multi-Way 2 31st July 2009 03:05 PM
jamo d365 the duke Multi-Way 0 17th November 2008 02:01 PM
Jamo Concert Vii JensRasmussen Multi-Way 3 8th March 2008 11:38 AM
jamo 7.5 speakers onlinejames Multi-Way 3 21st October 2006 10:59 AM
Page generated in 0.09804 seconds (77.46% PHP - 22.54% MySQL) with 10 queries
