Help choosing midrange driver
Old 14th October 2004, 03:05 PM   #11
Kittle is offline Kittle  United States
Nice looking driver...
the SPH 165 isnt on monacor's site, but they do have some others that look quite good.
But I cant seem to find a US or Canada based dealer.
Old 14th October 2004, 03:09 PM   #12
Leeuwarden is offline Leeuwarden  Netherlands
Try this: http://www.monacor.de/int/en/produkt...pr=EN&typ=full
Old 14th October 2004, 03:28 PM   #13
5th element is offline 5th element  United Kingdom
5th element's Avatar
Originally posted by Kittle
Cheap
The peerless 821615 looks good, except its almost double the rated power im targeting, id be a little worried about underpowering it.
There is no such thing as underpowering a driver.
You can have too little power mind you when clipping occurs, but just because a driver is rated at twice the rated power you want doesnt mean you cant use it.
The rated power is just a thermal characteristic anyway, how much power the voice coil can take before suffering heat exhaustion. The limiting factor in most cases is the excursion or mechanical limits of the driver.
You will notice that at 40hz with a 6.5" driver you will reach its max excursion with very few watts maybe 10 or less and more and the driver would suffer mechanical failure. But it would still be well within its rated power.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 14th October 2004, 03:50 PM   #14
thanks for the explaination
Time to chuck out yet another "urban legend" about toasting drivers due to not enough amp power.
Old 14th October 2004, 04:20 PM   #15
Yes and no. Its all about how much power the coil can take before getting too hot. Now when an amp clips it does cause the coil to heat up more but aslong as this is still within the coils acceptable limits you wont suffer damage.
Usually woofers dont get fried from amps clipping its tweeters that do, so you still have to be careful.
Old 14th October 2004, 07:00 PM   #16
Leeuwarden -- Thanks for the link. I guess your search skills are better than mine.
Any clue how to get some of those shipped to my doorstep? they dont show any north american based distributors
Old 14th October 2004, 07:06 PM   #17
Well if you are willing to order in Europe it is not that big problem.
One of the cheapest sources I know is this http://www.bmm-electronics.nl/Produc...roduct_ID=2729 company.
I thinkthey deliver worldwide. If not, you can always mail me and we work something out.
Old 14th October 2004, 07:21 PM   #18
ScottG is offline ScottG  United States
http://www.partsexpress.com/pe/showd...number=296-063
perspective is everything
Help choosing midrange driverHide this!Advertise here!
choosing specs for driver that will be used for OB c3conv Multi-Way 3 21st November 2008 07:28 AM
Midrange Crossover: Choosing the least of all evils? TheSeekerr Multi-Way 23 6th November 2008 09:20 PM
Help choosing a midrange up to $200/pair Mogar Multi-Way 10 30th November 2005 06:14 AM
Choosing a sub driver based on T/S... manxam Multi-Way 2 21st February 2004 10:16 AM
Choosing wattage for woofer, midrange, & tweeter JojoD818 Multi-Way 14 10th October 2003 07:22 AM
