http://www.yildiz.edu.tr/~ilkorur/bend3d.mpeg The link above is directed to a FEM simulation on my web page. I am a Ph.D. student and I am working on the mathematical model of TL enclosures. Unlike M.J. King model, I am working on a TL which has sudden area changes and acoustical filters, just to be able to use less damping material and improve the sensitivity performance. http://www.diy-systems.com/en-us/dept_10.html The link above shows in a way that it can be possible. But in order to perform optimization and fine tuning a math model is what I need ! After dealing too much with neural network approach and electro-acoustical modelling, the time has come to the hardest part. I have to build the mathematical model of the line with bends and all the other perturbations. Performing search over the scientefic databases yield some results but I have to reach to the core in order to understand the basics of modelling. Specially I need to model the reflected waves as given in the simulation above. As I have written in my messages in other subjects, if this subject is considered in complex terms the real part symbolises the energy transmitted through the elbow or terminus and the imaginery part symbolises the reflected one. I will be glad to receive any leads, links, information, comment on how to model such a behaivour. Thanks in advance. Regards Onur
Master is the master of his own Happiness |
#2 |
Well, I was going to send you a private message, but since you don't allow them, good luck with your quest.......
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 | |
Anyway, you haven't contribute but you can benefit from the result. http://www.yildiz.edu.tr/~ilkorur/ There is your simulation. Solves the hyperbolic wave equation on an Unbounded Domain so that you can simulate your favorite geometry and calculate the transmission loss. What this will bring to your work? Optimized absorber placement, standing wave analysis, finding the radiation pattern, oprimization of horn heometry, optimization of speaker placement in TL and other enclosures and so on. No, you don't need MatLab, and you don't need another >1K software, otoh you may benefit from Excel or a similar software for processing the output data. /Onur
#4 | |
#5 | |
No one has ever mailed to me and shared anything about NRBC, absorbing boundary conditions, non reflecting boundary conditions, Perfectly Matched Layers for Maxwells' Equations or their applications to Hyperbolic Wave Equations. But, instead I did receive mails about how they have solved the problem using MatLab, and how brilliant their solution was (nothing in terms of maths). I have received many advice, to leave the code aside since MatLab was doing more then enough and there was no need for such a code. I think I do have the right to complain against these "ego shows", although I am fully aware that this is my PhD thesis and I have to deal with it myself. Anyway, if you are talking in the name of other people who has interest in this and didn't prefer to help me with this code, then it is ok, nothing to say there, but if you are talking about yourself, please be confident that my words weren't aiming at your direction, since I will always be thankful for what you have done. /Onur
#6 |
I think most DIYers are not so mathematically involved. Some people have different goals that may not cross with what you are doing. Lonely path sometimes. About 80~90% of engineering solutions up to know, I had to figure out myself from whatever information I can find.
While your simulation looks cool. I think the way waves interact and change after the interaction effects what we hear. One partucular area is driver cone shape and configuration. Ever since I listened to drivers with phase plugs and without, I am convinced that the shape of the phase plug would benefit much more from FEM analysis than the transmission line, especially at the high frequencies. Of course the transmission line is very important also, but unless complicated acoustic filtering is desired, FEM modeling may not yield much differences from a larger scale analysis.
Hear the real thing! |
#7 | ||||
| Akabak: modelling horn bends and cross-section discontinuities | philpope | Subwoofers | 0 | 31st July 2007 02:02 PM |
| Horns, bends and upper mids | lndm | Multi-Way | 3 | 1st May 2006 10:22 PM |
| Calculating bends in a tapered TL | bwbass | Multi-Way | 12 | 5th February 2005 08:58 PM |
| Reflection Audio | BTW | Chip Amps | 0 | 31st October 2003 01:14 AM |
| Page generated in 0.12615 seconds (79.55% PHP - 20.45% MySQL) with 10 queries |
