Old 12th October 2004, 05:26 AM   #1
Default Woofers sound and respond different - what to do?
I've bought 2 Peerless 850122 drivers from Madisound. Both drivers exhibit different:
- cone displacement with a 25Hz tone
- sound different to my ears
I've tried a mono signal and swapped amp channels. It follows the drivers.
What can I do? I've already soldered cables to the terminals so I suppose return is not an option? I don't have an SPL meter / microphone. Would that be the best way to deal with it? Take measurements then attenuate one or the other if it is an efficiency thing?
I don't want to return and probably can't now I've soldered.
Please help!
Dave.
Old 12th October 2004, 05:33 AM   #2
Send a message via AIM to joe carrow
buy one more, and use whichever 2 of the 3 sound best together?
Old 12th October 2004, 05:40 AM   #3
Nasse is offline Nasse  Finland
Don´t have any experience on this but I remeber some speakers need few hours "playing in" before parameters settle to specs
But if they are both new and same batch...
Old 12th October 2004, 05:50 AM   #4
Bill Fitzpatrick's Avatar
Send them an email and ask them about it.
Old 12th October 2004, 06:01 AM   #5
One thing that just crossed my mind: Apart form the possibility that one of them may be faultiy or that they need more "burn in" -is it possible that one is a 4 Ohm and the other one an 8 Ohm version ? This could easily be checked using an Ohmmeter.
Charles
Old 12th October 2004, 11:09 AM   #6
joe_carrow:
Thanks - thought of that but there aren't any local retailers / distributors in NZ for this driver. Closest is Aus for AUS$89 + shipping and that would be hit and miss?
others re burn-in period
the first driver was only played by itself fro maybe 15 minutes. After leaving both with a Rammstein house mix overnight - no obvious difference. The excursion of one is about 1.25 times that of the other at any given volume / frequency (eg. a proportional and linear difference)
phase_accurate:
good idea - I hadn't thought of that. I'll need to borrow an ohmmeter / multimeter (yes - I'm the only human left without one ) and test. Both woofers do have model 850122 on the magnet (and I'm pretty sure the 850122 only comes in an 8 Ohm version).
I should get a mic and let the computer be the judge - to see if they are significantly different when measured.
I certainly trust my ears though... ah well - will have to wait and see. I'll try measuring the resistance, running in longer and we'll see what happens.
Thanks for your replies.
David.
Old 12th October 2004, 02:17 PM   #7
As long as you have the multimeter, you might as well measure the free air resonance.
An online tone generator is available here:
http://www.david-taylor.pwp.blueyond....html#SweepGen
And all you would then need is a resistor from 4-10 ohms.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 13th October 2004, 02:22 AM   #8
BassAwdyO's Avatar
Send a message via AIM to BassAwdyO
Default Factory defect
It sounds to me like you have a definite factory defect. If you tested the subs on the same amp and got different results it could only be due to one thing. That would be voice coil malfunction. Sometimes speakers dont fry voicecoils completey the voice coil laminate melts and the copper gets fused or shorted. In that case an entire section of coil gets "skipped" and the current passes through only a portion of the coil. I've seen this happen before. I wouldnt imagine the problem with your woofers is due to the voice coil of one speaker being fried, but a factory defect causing a similar situation. In the weak speaker probably only part of the coil is working due to a short somewhere in the coil. You should definately send it back. Even if it has been soldered, I've never heard of a warranty being void due to wires being soldered on. Check the impedence. I'm sure you'll find a difference
The golden rule of DIY:
Build nice, or build twice!
Old 13th October 2004, 02:27 AM   #9
Update:
I emailed Madisound and they promptly replied, saying they would happily allow me to return the 850122s and they would send back a matched pair (good service).
I presume here I will be paying for shipping (both ways) and considering it cost me (via Fedex) USD$50 (yes that's right) to get them here - it will be USD$100 to get USD$80 of matched drivers. Since I've also soldered the drivers, don't know if they will take them back anyway.
I think I'll just try them out and see how they sound.... I've got to get myself setup for measuring.
The other option is if I go the HT route - I could get another 2 as rears then choose the best 2 out of the 4 for the fronts.
Dave.
Old 13th October 2004, 03:00 AM   #10
If Madisound sent you defective merchandise they should pay shipping both ways for replacement.
How does one respond to this ..? ashok Everything Else 23 10th July 2009 06:51 PM
Irritating sound from HDS 8' woofers HiFiNutNut Multi-Way 10 21st April 2006 03:47 AM
2 woofers in single closed box -> metrology -> sound? capslock Multi-Way 12 1st August 2003 01:58 AM
Any moderator respond please Bill Fitzpatrick Everything Else 1 18th June 2003 01:29 AM
ticking sound in new woofers - cause, remedy? capslock Multi-Way 7 30th January 2003 03:57 PM
Page generated in 0.11124 seconds (77.66% PHP - 22.34% MySQL) with 10 queries
