Anyone though of using the Dayton RS drivers for a Orion Clone? I thought it would be great to do a dipole design using the 8" Dayton Rs and the Seas 27tdfc along with 2 Dayton RS 10" woofers per side. I would do this passively more than likely. thoughts?
#2 | |
1) Those dayton 10"s only have 6mm xmax. Keep in mind that the Peerless XLS 10" has almost twice the excursion. This will place a limit on how loud/low these will go. 2) It doesn't look like the 8" will go much past 1khz without major problems. link here This will give you a lot trouble mating it to that tweeter. Without an easily tweek-able active crossover; it'd be a real gamble to even attempt it. 3) Active crossovers- really a must. In addition to being able to tweak the crossover point and slope for good driver integration (and avoidance of nasty effects of pushing a driver to its limit), I think that the Orion uses an active equalization filter or two to tailor response. Here are a few suggestions- ->Definitely go active!! ->Consider an MTM with the Dayton 6" rather than a single 8". ->Seek another woofer for the bottom. I still haven't figured out if this is a good idea, but the dayton 15" IB could be attractive. Does anyone know how high they can play, or what their distortion is like? Just my two cents! Good luck on the project. Joe |
#3 | |
Dayton 8" RS graph I was looking at a Phoenix clone with either 2 8" or 7" RS drivers. They do have lots of potential. FWIW Doug |
| Peerless XXLS vs. Dayton Reference vs. Dayton Titanic MKIII ? | wigginjs | Multi-Way | 6 | 3rd March 2008 08:56 PM |
| Orion Clone driver height question | santiu | Multi-Way | 13 | 4th January 2006 02:30 AM |
| Dipole/Open Baffle: To go line array or Orion clone? | Chaucer | Multi-Way | 3 | 1st July 2005 06:35 PM |
| Dayton 6" reference and dayton silk dome tweeter combo project...input? | nerd of nerds | Multi-Way | 4 | 2nd December 2004 05:36 PM |
| Stryke AV12MkII vs. DPL12 or XLS for Orion/Bob5 clone? | NH7RO | Multi-Way | 18 | 15th May 2004 03:19 AM |
| Page generated in 0.07284 seconds (71.76% PHP - 28.24% MySQL) with 10 queries |
