Old 9th October 2004, 10:44 PM   #1
wingman is offline wingman  Denmark
Default TL and monacor will it work ?
data Click the image to open in full size.
Technical datasheet
Impedance (Z) 2 x 4 Ohm
Free air resonance (fs) 21.5Hz
Max. frequency range f3–800Hz
Rec. crossover freq. (fmax.) 400Hz
Music power 2 x 400WMAX
Power rating (P) 2 x 250WRMS
SPL (1W/1m) 89dB
Suspension compl. (Cms) 0.28mm/N
Moving mass (Mms) 199.5g
Mech. resistance (Rms) 9.6kg/s
Mech. Q factor (Qms) 2.81
Electr. Q factor (Qes) 0.31
Total Q factor (Qts) 0.28
Equivalent volume (Vas) 275 l
RDC DC resistance (Re) 2 x 3.6 Ohm/1 x 7.2 Ohm
Voice coil induct. (Le) 2 x 1.1mH/1 x 4.4mH
Voice coil diameter 75.5mm
Voice coil former aluminium
Voice coil winding height 34.2mm
Air gap height 12mm
Linear excursion (X) ±11.1mm
Eff. cone area (Sd) 845cm²
Volume displacement (Vd) 938cm³
Force factor (BxL) 25.0Tm
Reference efficiency (No) 0.86%
Magnet diameter 180mm
Magnet weight 130oz.
Mounting cutout ø 356mm
Mounting depth 180mm
Dimensions ø 402mm
Weight 11kg
Rec. net cabinet volume
closed 55 l
bass-reflex 110 l
i have one idé from GM, here goes:
Suggested ML-TL:
L = 62"
width/depth (CSA) = 270.6"^2
driver down from top 24.63"
5" diameter x 12" long vent near/at the bottom
0.2-0.4lbs/ft^3 stuffing density
GM
i have 2 and i need them for music and small PA
the room they will paly in normaly is 35x12x3.25m
Thanks for your input and help.
bass is also audio
Old 10th October 2004, 04:56 AM   #2
GM is offline GM  United States
GM's Avatar
I do not recall posting this, but it is an EBS alignment tuned to ~16Hz for sticking in a corner for HIFI/HT apps. For PA apps in a large room you want more acoustic efficiency higher up, so a ~T/S max flat alignment is what is normally used:
L = 30.8"
width/depth (CSA) = 171.723"^2
driver down from top 13.78"
5" diameter x 10" long vent near/at the bottom
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
What about Monacor? mr_push_pull Multi-Way 8 17th October 2010 10:41 PM
Monacor sph-135/AD Tomac Multi-Way 22 30th August 2006 04:30 PM
Monacor MSH-115 (116) Michail Bugaria Multi-Way 5 16th May 2006 07:45 AM
monacor goran14 Multi-Way 2 20th April 2005 02:12 PM
Monacor Vedo Multi-Way 2 10th February 2005 09:31 PM
Page generated in 0.07806 seconds (69.88% PHP - 30.12% MySQL) with 10 queries
