Old 7th October 2004, 09:50 AM   #1
nOOSE is offline nOOSE  Australia
Default parrallel or series
Hi it's me again,
I'm building the wesnor ellas and i'm wodering if i wired them wrong.
The woofer is rated at 8 ohms and the tweeter is 6ohms.
Now i think i wired these in parrallel so that would have an impedance of about 4 ohms rite?
My amp is rated at 8ohms.
Should i wire the drivers in parrallel or series and what is the best way of wiring in series or parralel.
Thanks,
nOOSE
Old 7th October 2004, 10:24 AM   #2
4real is offline 4real  Netherlands
Send a message via ICQ to 4real Send a message via MSN to 4real
Default Re: parrallel or series
Don't you need a filter?
Old 7th October 2004, 01:01 PM   #3
Banned
You don't wire them in series or parallel- you wire them to the respective LF/HF outputs of your crossover.
Old 8th October 2004, 01:31 AM   #4
now i'm just confused..
please explain?
nOOSE
Old 8th October 2004, 02:12 AM   #5
please explain?
nOOSE
Your first post makes it sound like you left out all this stuff:
and were just wiring the drivers together with nothing else.
Perhaps you should clarify a bit - you DID build the crossover, right? Is your question perhaps how to wire the inputs to the filter sections...? If so, the answer is effectively "parallel"; you wire both of the "source" wires to your positive binding post, and both the grounds to your negative binding post.
Old 8th October 2004, 04:38 AM   #6
yeah that's what i did just wanted to clear things up ..
thanks.
nOOSE
Old 8th October 2004, 07:36 AM   #7
Pan is offline Pan  Sweden
I guess you can say that the drives are paralell, however that´s the way it should be.
You do not need to worry about impedance dropping low. The x-over direct the signals to the drivers so bass frequencies sees the woofer impedance, and the tweeter signal sees the tweeter impedance.
If you would connect the drivers directly to the same amp without crossover then you would end up with the lower impedance that you first thought would happen.
/Peter
Parrallel/bridged LM4780 ?? pat allen Chip Amps 5 28th December 2006 04:00 AM
16 bits stereo parrallel dac djdamix Digital Source 0 16th August 2005 12:48 PM
speakers in parrallel pfloyd_is_god Multi-Way 4 13th October 2004 10:38 PM
Parrallel / Bridge amp soundNERD Chip Amps 2 22nd October 2003 06:26 PM
Page generated in 0.22518 seconds (30.48% PHP - 69.52% MySQL) with 10 queries
