ive just been given, yes for free!! an eminence Beta15, the new 350 watt ones, its got a bit of scuff dammage on it, the shop was ram raided!!
so i was thinking, could i build a quarter wave box, to use as a centre speaker. i know i could!! but ive never been good at designing things, and dont have much computing and design stuff, i only got abacus last week!! so any help with plans and or plots would be great. cheers guys, steve.. ..
you all laugh because im different, i laugh because youre all the same.. .. |
#2 |
Uh....
Why would you want to use a large woofer as a center channel speaker? It's mid-range response is going to be pretty ragged and HF is non-existent. |
#3 |
because its backed up with motorola mid / high horns and apt80 compression tweeters. and i want to see if i can do it, if i can, i may go and buy another beta15 and move them to front pair. c u later, steve.. ..
#4 |
Banned
A Beta 15 has usable specs for a QWTP, but you're going to end up with a minimum 6 cu ft box, which frankly is silly for a center channel. It could be made good to 30 Hz in a ten foot pipe- but that's what subs are for. Even L/R mains don't need to go below 80 Hz.
#5 |
at the moment its in a 200 litre box, but the box is damaged, 6 cu.ft. is ok. but now your talking with a 10ft pipe!! yum, yum. what sizes would you recomend? or what software that is easy to use, and freeware!! so i can model it myself? see you soon, steve.. ..
#6 |
http://www.quarter-wave.com/
YouŽll need to download the sheets you need and the mathcad-explorer. You should also read the articles there ,check out Bob Brines homepage and just search here through the forum.
jens |
| Quarter Wave TL's and various Questions. | demon2091tb | Multi-Way | 4 | 22nd November 2006 06:19 PM |
| Help (very much) wanted for simple quarter-wave design for cheap drivers. | Spasticteapot | Full Range | 9 | 4th May 2006 09:14 PM |
| Quarter Wave Recommendations | Kofi Annan | Multi-Way | 37 | 2nd June 2004 02:44 AM |
| Martin King: Is it just me or quarter-wave.com is down? Thanks | JC Fardo | Multi-Way | 7 | 12th September 2003 11:15 PM |
| Page generated in 0.08397 seconds (71.53% PHP - 28.47% MySQL) with 10 queries |
