Old 5th October 2004, 03:27 PM   #1
4real is offline 4real  Netherlands
Send a message via ICQ to 4real Send a message via MSN to 4real
Question Active filter test software
I'm looking for an application to test an active filters with the soundcard and standard stereo or multichannel amp.
One channel for each speaker, so a stereo card should be fine for a 2-way filter. Every channel should be configurabe with the digital equivalent of the analog active filter.
I want to use this to test an active filter, before actualy building it Should be possible, but I cannot find any software that does it.
lspCAD comes close, but you need to tweak it a lot to use it for my purpose
So any contibution is welcome, and of cource, if possible it schould be free, of freely testable
Old 5th October 2004, 05:57 PM   #2
joensd is offline joensd  Germany
If you happen to have a Soundblaster card with either 10k1 or 10k2 chipset (certain audigys ,live etc.) then THIS will be perfect for you needs.
You can setup any filter you like and send it to any output of the card you like. Very nice alternative to Creative´s drivers.
I still haven´t tried the drivers but do a search in the forums and you´ll find quite a bit of information.
AsioXO is another alternative and if you´re a Linux user there´s even more software that´d do the trick.
jens
Old 5th October 2004, 06:00 PM   #3
To bad, no SB...
But I like the linux bit Could you give me an application that will do what I want? Would be great
Found some stuff here: http://linux-sound.org/dsp.html
Old 5th October 2004, 07:41 PM   #4
Digital active XO+eq using a PC+soundcards+BruteFIR?
http://www.ludd.luth.se/~torger/brutefir.html
http://www.diyaudio.com/forums/searc...der=descending
Hope that´s enough to read.
Cheers
jens
Old 5th October 2004, 07:43 PM   #5
Yep, already tried some stuff But no succes yet (have little time at the moment).
But i'll keep you posted
Active filter design software lochness Tubes / Valves 25 11th July 2008 12:04 AM
design software for active filter dick van nierop Chip Amps 7 20th March 2006 04:25 PM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
FilterLab® Active Filter Design Software peranders Everything Else 0 24th March 2004 11:33 AM
Page generated in 0.08363 seconds (72.13% PHP - 27.87% MySQL) with 10 queries
