Ellis 1801bf for your inspection
Old 4th October 2004, 10:06 PM   #1
ultrachrome is offline ultrachrome  United States
Default Ellis 1801bf for your inspection
Finished in fine bedliner. Used two cans of Duplicolor for the pair but needs a third.
The cabinet didn't turn out as straight as I wanted so I thought I'd try the aerosol bedliner so I didn't have to live with MDF boxes until I had time to rebuild. Really suprised the way it turned out. May never get around to rebuilding them.
Originally built as stand mounted (maple veneer and solid african mahogany baffle) but cut the driver holes wrong after all that work. Mainly a cosmetic problem, but Excels aren't exactly drivers you want to cover up with a grill.
Old 4th October 2004, 11:39 PM   #2
THOR is offline THOR
Send a message via ICQ to THOR Send a message via Yahoo to THOR
Default very nice ! how do they sound?
id like to know ur results
If it aint Baroque , fix it !
Old 4th October 2004, 11:59 PM   #3
Al Garay is offline Al Garay
Where are you in Puget Sound? Looks nice. What are you using for electronics?
Al
Old 5th October 2004, 04:58 PM   #4
They sound great although a little bass shy in the new enclosure, probably because the port is too long. I'll fix that shortly.
Right now they are running off a Panasonic XR45 but usually they're powered by a stock AKSA 55 and sligtly modded Foreplay.
The rack contains an unfinished BrianGT gainclone, an AKSA 55, Dynaco ST-70 with cap mod, and at the bottom is an empty rack mount enclosure that will probably house a DoZ.
I've a grounded grid pre in the works and am debating whether to upgrade the Dynaco input section or the AKSA Nirvana mod. Have a lot of projects saved up for winter!
Old 5th October 2004, 06:37 PM   #5
Can you compare the Gainclone with the AKSA 55 especially in the highs?
I use the AKSA 100N to drive my 1801b. Was thinking of going active with the Gainclone driving the OW1s and AKSAs driving the Excel W18 woofer.
Al
Old 5th October 2004, 06:46 PM   #6
Pan is offline Pan  Sweden
Al G,
I would expect better results the other way around.
/Peter
Old 5th October 2004, 08:37 PM   #7
I built a pair of BrianGT's NIGCs, one with the tweeky resistors he offered and the other with Vishay-Dale RN60Ds from Welborne Labs. Both used 1500uF Panasonic FC capacitors and the same power supplies with a single 330VA 25-0-25 transformer per stereo pair.
I listened to them for a week or two before going back to the AKSA. I was very relieved that the time, effort, and funds invested in the AKSA proved to be worth it.
I haven't done extensive A/B-ing but the AKSA is definitely more spacious and 3D sounding. The NIGCs were fun and maybe they could use more break-in, but I strongly prefer the AKSA.
I'll use the NIGCs with other systems.
I did try horizontal bi-amping the 1801s with the NIGCs but the gain is slightly higher on one so it was either too bright or too dark.
For my next amp project I'm trying to figure out whether to perform the Nirvana upgrade on the AKSA or upgrade the driver of the Dynaco.
Old 8th October 2004, 07:18 AM   #8
Commo is offline Commo  Poland
Ultrachrome, how do You find Panasonic XR45 sound, there is some hype about this receiver. Since You have Gainclone, AKSA and Panasonic Your opinion would be most interesting to me.
Ellis 1801bf for your inspectionHide this!Advertise here!
X-ray inspection Nixie Parts 0 9th February 2007 02:55 AM
Looking for Voss-Ellis article HugoR Tubes / Valves 5 26th January 2007 05:09 PM
cabinets for ellis 1801 bigredcup2004 Multi-Way 2 26th March 2006 08:40 PM
Ellis 1801 conceived ultrachrome Multi-Way 19 2nd February 2004 11:00 PM
Utopia OW1 vs Ellis 1801b Jhovis Multi-Way 2 11th September 2003 01:30 PM
