want to know if i can use the auricap from partsconnexion to replace my solen 8.2uf 400v with a auricap 8.2 200v.will the voltage make a difference?and i have a solen 18uf 400vwant to replace it ,but the only value i see is a 20uf 200v ,will this work?
and i can't find Riedon 10 watt resistors in canada? it is the odin crossover design.please help asap.thanks
#2 | |
You can make a 18 uF parallelling caps, then you can simply add the values, and get a closer match. Again, thet voltage is oke. |
| Crossover for vifa 2 way setup - how can I find out what this crossover is doing? | Tino | Multi-Way | 11 | 17th May 2009 04:21 AM |
| Help me with a crossover. | raypalmer | Multi-Way | 4 | 5th April 2009 01:48 AM |
| Passive crossover into active crossover | hahfran | Multi-Way | 16 | 10th February 2008 06:16 PM |
| Crossover help please :) | Tenson | Multi-Way | 17 | 15th April 2006 09:34 AM |
| Can you hear the crossover point of a speaker with a well-designed crossover? | 454Casull | Multi-Way | 11 | 2nd April 2004 05:48 AM |
| Page generated in 0.06348 seconds (74.23% PHP - 25.77% MySQL) with 10 queries |
