How would one figure the ts paramters of two drivers, so they could be modeled as one? would VAS, and QTS double? What about QES if the drivers were wired in series? and parallel? and what about QMS?
#2 |
If you go to my site and look under the general speaker articles there is a write-up that answers your questions. I have a sample problem that should help explain the pro's and con's of each type of wiring.
Hope that helps, |
#3 |
Thanks for the reply! I know about both types of wiring, just never had to model them this way before.
#4 |
Read the article.. while it is helpful, I don't think it gave me everything I need.. Am I completely blind?
#5 |
Banned
All that is really significant is the Vas, which doubles assuming you're not going isobaric, and halves if you do. Model in WinISD; it will model as many drivers as you wish. Series versus parallel is 90% a matter of just keeping the total load where your amp is happy with it. You can get more picky if you wish, but keeping the impedance load within the usual 4 to 8 ohm window also keeps everything else from getting hinky as well.
#6 | |
#7 |
Thanks for the help, but I'm not doing just a simple ported enclosure. If I were, I could just use winisd and select two drivers
#8 |
If
"a" is the number of elements that are connected in series, electrically, "b" is 1 for normal configuration, 2 for isobaric configuration and "n" is the total number of elements, the new values are calculated as: Vas=Vas1*n/b^2 Bl=Bl1*a Sd=Sd1*n/b Re=Re1*a^2/n Le=Le1*a^2/n So two drivers in series, side by side has a=2, b=1, n=2 and Vas=2*Vas1 Bl=2*Bl1 Sd=2*Sd1 Re=2*Re1 Le=2*Le1 |
#9 |
Perfect!! Thanks a ton!
| TS parameters and specs for these drivers??? | Bull | Multi-Way | 1 | 9th March 2011 12:15 PM |
| T/S parameters for horn drivers | buggsson | Multi-Way | 7 | 25th March 2008 08:53 AM |
| Parameters for drivers | iwahn | Subwoofers | 0 | 20th June 2007 09:13 PM |
| T/S parameters for Hokutone/NMB drivers? | m@ | Multi-Way | 0 | 4th March 2005 06:38 AM |
| T/S parameters of JBSystems drivers | sstoiana | Multi-Way | 1 | 30th September 2003 08:11 PM |
| Page generated in 0.09987 seconds (76.11% PHP - 23.89% MySQL) with 10 queries |
