Old 2nd October 2004, 05:37 AM   #1
AJ is offline AJ  United States
Default Line array wire
I'm going to be building a new line array after liking what I heard from my last one (69 cent PE mid/bass and PT2 tweeters) and I want to do a keeper build on this set. On the last set, I wired all the drivers with whatever I had on hand, which turned out to be RS hookup wire of 24ga. Since LA's have so much wire in them, as opposed to say a simple 3-driver box, I'm thinking of using something suited to it - maybe larger diameter???
I'm not a wire freak, so there's no way I'm gonna spend 100 dollars a foot on boutique stuff, but what do you guys suggest for decent wire when you're gonna have a rather large amount of it in the speaker? Does it make sense to go to say, 16ga just for the sake of lowering resistance if nothing else? Or am I getting anal about something I don't need to?
It's kinda tricky to A/B something like this, so once I close up the box, that's it.
Thanks,
Allan
Old 2nd October 2004, 01:14 PM   #2
Banned
24 ga is a bit small, you'll have some resistance issues. Go with 16 or 14 ga, don't waste money on exotics. The Sound King wire at Parts Express is quite adequate.
Old 2nd October 2004, 02:09 PM   #3
I built two of the PE/Onkyo and PE/PT2 LA's. I used 12 Ga. wire on both. In the first case, I used a stranded wire. For the next project, I went to a solid so that I could fab up all the "jumbers" and make a neater back.
All the connectios were soldered. I soon abandoned the iron and went right for the "mini" torch. Much faster and ultimately does a better job.
Old 2nd October 2004, 05:05 PM   #4
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Solder the wires to the drivers before mounting. It make the job much easier.
Everyone has a photographic memory. It's just that most are out of film.
Old 2nd October 2004, 05:09 PM   #5
Yup.
Ok to wire line array in series? Why? jaekfre Multi-Way 8 3rd August 2009 02:23 PM
line array + transmission line ? zobsky Multi-Way 12 16th August 2006 04:18 PM
Line array tweeter line - On left or right? dhenryp Multi-Way 4 9th March 2005 11:35 PM
how to combine Line array and transmission line together Jared Multi-Way 5 19th April 2004 10:32 PM
t-line subs for a DIY line array tom1356 Multi-Way 17 28th December 2002 12:15 AM
Page generated in 0.07981 seconds (74.77% PHP - 25.23% MySQL) with 10 queries
