port turbulent jet noise. any advice? - Page 3 - diyAudio
Old 4th October 2004, 10:17 AM   #21
Artmaster's Avatar
Send a message via Skype™ to Artmaster
Originally posted by paulspencer
Your vent should be flared on both ends to perform at its best.
Another way to reduce port noise which has not been mentioned is to use a rumble filter. This reduces the velocity further and can make a big difference.
is it realy work? I never made it before. ok. thank you. I'll try.
about rumble filter. do you mean low-pass filter? I have it. 12 db/oct. 12-14 hz. wont make it higher.
and no another filters. anyones. it's always make sound poor
Artmaster live in www.artmaydan.org.ua
Old 4th October 2004, 12:07 PM   #22
paulspencer's Avatar
yes flaring on both ends does work!
No, a rumble filter is a highpass filter. A good rumble filter would be at least 4th order and preferably 6th order @ 20 Hz.
Old 4th October 2004, 12:46 PM   #23
Artmaster's Avatar
oh! sorry. my mistake. course - highpass filter. I have it.
ok. I'll try to make flared on both ends port will see
Old 4th October 2004, 12:49 PM   #24
a few ways to do it:
1. make a template and apply heat to the PVC vent and push it so that it stretches - you can get a small radius this way
2. attach to MDF and use a router bit eg. one inch
3. turn up a larger flare on the lathe
Old 4th October 2004, 01:00 PM   #25
Artmaster's Avatar
[QUOTE]Originally posted by paulspencer
[B]a few ways to do it:
explain please
Old 4th October 2004, 01:53 PM   #26
you attach the vent (PVC) to MDF into which is cut a hole. You then attach this to the baffle on the outside. You use a router bit to get a radius on the outside edge.
Old 4th October 2004, 11:17 PM   #27
Send a message via MSN to noodle_snacks
I used the router method and it works quite well. Take it very slowly with the PVC pipe and use a fairly powerful router as the PVC is generally quite a bit harder than wood. Once you have done it you can fill any small gaps that have been made with putty etc.
Old 5th October 2004, 04:24 AM   #28
It's not necessary to cut through the vent with the router if you use a separate mounting ring, which is in fact an easier way to make the vent presentable.
Old 5th October 2004, 06:08 AM   #29
Artmaster's Avatar
thank's for picture, paulspencer! it's easy for understanding.
pity, but even egg-glass port with exponential borders couldn't sound well. it's has lot of distortion, cutting-off effects. less a little then simple pipe.
that's right. I can't change law of physics.
but I realy get acceptable quality level with smaller port diam - 50 mm instead 75 mm, 100 mm, 2 pcs of ports diam 75 mm.
probaly it's ok for me, but I'll test any more ideas
Old 5th October 2004, 11:37 AM   #30
If the noise is still a problem when playing music/movies or whatever (Port noise with sine-waves isn't really anything to worry about) then try stuffing the port slightly with some sort of acoustic stuffing like polyfill or dacron. The output of the port will be reduced but so will port noise.
Port noise CARTRulz Subwoofers 6 13th June 2006 12:27 PM
port noise minimise Artmaster Subwoofers 26 1st December 2004 06:08 AM
Port noise problem ernieretief Multi-Way 9 4th August 2003 08:11 PM
Port Noise, Wind Speed................. OMNIFEX Multi-Way 20 13th April 2003 04:27 PM
Port Noise Redeye Multi-Way 19 11th February 2003 09:47 PM
Copyright 1999-2017 diyAudio
