port turbulent jet noise. any advice?
Old 5th October 2004, 12:12 PM   #31
Artmaster is offline Artmaster  Ukraine
Artmaster's Avatar
I'm afraid - it's not exactly
noise exist anywhere. sine, music signal - have not difference.
you're right. should I cover tube of port inside demping material, noise decreased.
ok. looking for the best way again
Artmaster live in www.artmaydan.org.ua
Old 6th October 2004, 01:49 AM   #32
noodle_snacks is offline noodle_snacks  Australia
Send a message via MSN to noodle_snacks
Try some stuffing. You can get it from any material shop pretty much (ask for pillow stuffing etc) and see what the results are, you can experiment with varying amounts until the port noise is gone. If stuffing the port rolls off bass response too much and you can think of no other options you might consider converting it to sealed and adding a powered subwoofer to do the bass instead.
Old 6th October 2004, 06:11 AM   #33
Artmaster's Avatar
thank you noodle_snacks!
I'll experimenting again and again. of course, I can add any power to sub, but it'll add noise either.
now i try to unload of noise for nominal power for my 10" driver.
it's about 86 db. it's a little output, but it's enough for me.
port turbulent jet noise. any advice?Hide this!Advertise here!
Port noise CARTRulz Subwoofers 6 13th June 2006 12:27 PM
port noise minimise Artmaster Subwoofers 26 1st December 2004 06:08 AM
Port noise problem ernieretief Multi-Way 9 4th August 2003 08:11 PM
Port Noise, Wind Speed................. OMNIFEX Multi-Way 20 13th April 2003 04:27 PM
Port Noise Redeye Multi-Way 19 11th February 2003 09:47 PM
Copyright ©1999-2017 diyAudio
