Old 30th September 2004, 09:02 AM   #1
falcott's Avatar
Default DSE active crossover kit
Has anyone (in Australia or New Zealand) had any experience with, or can comment on, the Dick Smith active crossover kit K5404?
Here is the only info about it on the website:
>Allows you to integrate a subwoofer with an existing speaker system. Offers both low-pass and high-pass outputs which have matching roll-off and phase characteristics. Input and output impedances: 47k and 100 ohms respectively.<
To be honest, as a neophyte I don't fully understand the relevance of the input/output details. But the kit is CHEAP (NZ$16 at present). They are clearing them out and will not be restocking.
Worth buying, you think?
"Everything should be made as simple as possible, but not simpler." - Einstein
Old 30th September 2004, 09:08 AM   #2
kiwi_abroad's Avatar
I built one years ago for a friend. Worked well for his home setup but it's just a simple op-amp based circuit. Don't expect 'audiophile' quality, but for home theatre / casual listening it does the job.
Don't forget you have to build a power supply, and buy a case and RCA connections as well.
Adrian
active crossover: fir vs iir netchris Everything Else 3 29th July 2008 09:14 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
PA vs DIY active crossover paulspencer Multi-Way 46 27th November 2004 01:25 AM
active crossover aaronboumans Analogue Source 4 31st May 2003 04:59 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Page generated in 0.06806 seconds (69.68% PHP - 30.32% MySQL) with 10 queries
