I would like to have thoughts about mixxing those u different technology together ...
i will be building a loudspeaker system for a friend of mine in october, i have lots of things planned. What i want to build is a < 7' array of 5-6.5" woofers + ribbons 2 way system ! I want to know if it is a good idea to try and match ribbons with woofers? I would like to be able to use cheap stuff from parts express ... such as : BOHLENDER GRAEBENER NEO8PDR PLANAR TRANSDUCER http://www.partsexpress.com/pe/showd...number=264-713 maybe 2 of those on each side probably near the middlle can you recommend those units? would like to use it from 5KHz+ since it looks extremely stable in impedance load, it should be easier to match for amplification ? ( wich will be from the same amp for both mid and highs) still not sure about matching this to cone woofers woudl i be better using cheaper textile tweeters? but alot of them ? btw..it will be an open baffle type ( dipole ) thanks all |
#2 |
diyAudio Senior Member
I think this has been discussed here before.... Maybe a local search will unearth some of it. Nonetheless, it's certainly possible but you'll need a very fast woofer. One way is to use a dipole, open baffle system with a subwoofer if the lowest bass is a must. Quite often arrays of smaller woofers are used to improve transient response in conjunction with a ribbon mid/high ribbon. Either way, when the match is successful you're not likely to return to a conventional box system IMO. Cheers,
Frank |
#3 |
ahah
thank you, this is my planned route Will be using multiple drivers ( maybe 8 or 12.. ) for the woofer area what kind of frequency separation i should be using with this kind of 2 way setup ? is 5khz a good point? i'll do more searches, dind't find much info on the last ones .. i'll broaden it a bit |
#4 |
This maybe inspire a bit
http://www.dali.dk/prevbrochures/skyline.pdf http://www.dali.dk/prevbrochures/skylite_1000.pdf http://www.dali.dk/PDFFILES/premanua...YLINE_1000.pdf http://www.dali.dk/PDFFILES/premanuals/DALI_DACAPO.pdf This dude uses Dali Dacapo The DD's mod. with a pair of Gamma VLD-12 ribbon-tweeters (14KHz/6dB) horn removed, active subwoofer takes over the task below 80Hz
Mod is fun |
| Matching dispersion between ribbon and woofer | Defo | Multi-Way | 8 | 12th June 2009 12:29 AM |
| GEC metal cone speakers and kelly ribbon tweeters | weegs | Full Range | 9 | 17th August 2007 04:24 PM |
| FS Usher 8945a woofers, neo8 planars | Ang | Swap Meet | 3 | 22nd July 2007 02:28 AM |
| FS: RCM HE5.25-S Aluminum Cone woofers | pkpickard | Swap Meet | 2 | 1st April 2004 07:51 PM |
| Page generated in 0.08619 seconds (70.64% PHP - 29.36% MySQL) with 10 queries |
