Titanuim tweeters
Titanuim tweeters
Old 30th September 2004, 05:30 PM   #11
tenderland is offline tenderland  United States
tenderland's Avatar
Default tweeters
The speakers I am using are MB quart Q SD216
the front stage uses 2 soundstream amps with a Arcaudio
mx1 xover. the tweets are driven with a soundstream Class A 3.0 amp and the tweets are in the lower front corners off the doors. this spot is optimal for imaging.
the OEM xover point on the passive xover is 2.4khz
I am finding as you move the point up from that you loose some presence and vocal quality. I have been trying to tune this sytem for 3 weeks. ( I like the B@W S in the car idea I now i will gut the speaker ,take the tweeter................
Thank you jeff
Old 1st October 2004, 04:05 AM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Titanuim tweeters
you no doubt are hearing the side effects of a hi-Q resonance... i'd try a coat of puzzlecoat on the back side of the dome. I've had good resulta taming the ringing on aluminum cone drivers.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st October 2004, 06:47 AM   #13
Taco is offline Taco  Netherlands
My experience with MB Quart tweets is the same. For me those tweets always seems edgy with female voices. The detail is very good and presentation is very airy.
Old 5th October 2004, 03:40 PM   #14
holger honda is offline holger honda  United States
Default try toiletpaper
Try to cover the tweeter with toiletpaper!
Try some different brands,some say that recycled have a sweeter sound in the upper regions,but my personal preference is cleenex (peach scented).Since this is for a car you might also consider hanging wonderbaums dangeling in front of the tweeter to randomly diffuse the harshness.
This migth not improve the actual sound but it will maybe smell better inside the car.
Good luck !
thanks for reading.
H.Honda Chico CA Land of the fooled
Titanuim tweetersHide this!Advertise here!
tweeters tonysherwin Swap Meet 0 22nd April 2008 12:16 PM
Which tweeters should I use? TurboFC3S Multi-Way 3 17th February 2007 01:46 AM
Tweeters? ThSpeakerDude88 Multi-Way 23 19th March 2006 06:59 PM
FS: Phy-Hp tweeters Sjef Swap Meet 2 29th October 2004 08:33 PM
Tweeters Vivek Multi-Way 13 23rd October 2001 10:06 AM
